Jamb For Closet Bifold Doors - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Larryh86GT
Old 02-12-2013, 10:31 AM   #1
Rewards Points: 1,010
Jamb for closet bifold doors
I have a 48" wide closet I'm working on, and I'm planning on installing two 24" wide bi-fold doors. Since I'm using two doors in one opening, obviously these are not pre-hung doors. Can I place drywall along the jambs and mount the hinges to that using screws that are deep enough to go well past the drywall and into the studs? Or do I need to have a wood surface on the jambs?
I'd prefer to use the drywall if I could so I could have a smooth, paintable surface.
spaceman spif is offline   Reply With Quote
Old 02-12-2013, 10:37 AM   #2
Newbie Bill
Rewards Points: 522
I thought bifold doors hinge on pins at the top (with a track) and the bottom. No hinges on the jambs.
Am I missing something?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-12-2013, 10:42 AM   #3
You know, you could very well be right. I haven't bought the doors and opened them to see, I just assumed they had hinges on the sides like other doors.
This might qualify as my derp-de-derrrrr moment of the day.
Old 02-12-2013, 10:45 AM   #4
Newbie Bill
Rewards Points: 522
I haven't seen too many jambs done with drywall, most of them are wood to match the jambs/trim of other doors in the home.
When we did our reno, we did the jambs and trim in MDF and it was all painted the same colour. So were the doors for that matter.
Bill
Old 02-12-2013, 10:52 AM   #5
Newbie Bill
Rewards Points: 522
Here is a quick photo I got from the internet. You can see the track along the top. You can also barely see the pins that go up into the track from the door corners.
Bill
Old 02-12-2013, 11:05 AM   #6
Newbie Bill
Rewards Points: 522
And an image of the hardware and track.
Bill
Old 02-12-2013, 02:34 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
all my bifold doors have drywall casings, make sure tiye track at top and pins at bottom are plumb
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-12-2013, 02:47 PM   #8
Rewards Points: 14,312
There's a differant rough open if your going to use drywall returns.
It's written right on the outside of the box the doors come in what size to make the opening.
Drywall returns are far more subject to damage.
Old 02-12-2013, 07:00 PM   #9
Rewards Points: 512
typically there is a piece with a knob that the door sits on and swivels on that http://www.homedepot.ca/product/bi-f...are-kit/977330 the metal piece sits on the floor and is screwed into the bottom of the jamb. so your going to have to stop your baseboard somewhere which look a little funny and you have to drywall right to the floor and butt your flooring right up to the wall. then there is a top track that has to be screwed into some meat. make sure you have long screw and dont screw in to tight so you dont crack the drywall or suck the track into the drywall.
princelake is offline   Reply With Quote
Old 02-13-2013, 07:50 AM   #10
Rewards Points: 77
a nice piece of 1x6 or 1x<whatever width the jamb is> should provide a smooth surface for painting and provide the rigidity you'd need, if any type of mounting is required for it. Most closet jambs are wood to handle the stresses and traffic (think shoes kicking the corners for example.). If you do go the drywall route, ensure to use corner bead or some other form of corner support.
dengle is offline   Reply With Quote
Old 02-13-2013, 11:19 AM   #11
That's exactly what I was thinking last night and I picked up some 1x6 paintable wood for that reason. I could have done drywall, but then I thought "I'm going to be carrying boxes and clothes in and out of these closets all the time, so the odds of an occasional bump and scrape are pretty good".
I'll have to cut back some of what I've already done to fit in the wood, but I think it's the right way to go. Thanks again, alla you!
Old 02-13-2013, 02:37 PM   #12
Rewards Points: 194
My 1950's ranch's 4 closets all had sliding doors that I replaced with pine bifold doors. They just have drywall openings. If you are using stained wood doors you might want to rip a piece of pine to fit the face of the top track, stain it to match your doors, then glue it to the face of the track.
Jamb for closet bifold doors-bifold-doors-002.jpg   Jamb for closet bifold doors-bifold-doors-003.jpg   Jamb for closet bifold doors-bifold-doors-004.jpg
jlhaslip likes this.
Larryh86GT is offline   Reply With Quote
Old 01-09-2017, 03:59 PM   #13
Rewards Points: 52
Re: Jamb for closet bifold doors
Larry, how did you get the old sliding door tracks out? And what did you have to do to cover over it in the jamb? I have a thread going with a similar type project and I'm stuck. You can look at my album to see what I'm dealing with. Just want to put up some bifold doors, haha. Thanks in advance!
DIY_Gal is offline   Reply With Quote
Old 01-16-2017, 07:15 PM   #14
Rewards Points: 194
My sliding door tracks were screwed in so it was easy to remove them. New carpeting covered the holes in the floor. I had rip cut the tops and bottoms and remove the hinges and rip all the sides of the doors to make them fit right.
Bifold cabinet doors with non-standard height opening python-django Carpentry 4 02-08-2013 08:56 AM
Opinions, bypass or bifold doors Michaelpro Windows and Doors 3 03-14-2012 11:00 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
Ideas for building custom bifold doors? crashley1784 Carpentry 1 02-18-2010 02:49 PM
