J Bead?? Or Traditional 90 Degree Corner Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 06:29 AM   #1
Rewards Points: 156
J Bead?? Or traditional 90 degree corner bead
I have a question peeps. I have a 90 degree outside corner that is going to be tile on one side with durock as my foundation then on the other side of the 90 is going to be greenboard. My question is should I use a J bead and attach it to the greenboard then make that flush with the durock and put fibertape over the joint then thinset on the tile side and regular mud on the greenboard side or do I use a 90 degree piece of corner bead and build the corners out like you normally would. I have bullnose tile going up to edge then it will transition to painted wall on the opposite side of the 90 outside corner. Let me know. Thanks
ryan5068 is offline   Reply With Quote
Old 05-13-2010, 09:01 AM   #2
Drywall contractor
Rewards Points: 1,070
Either method would work, but if you have any issues down the line and have to do a repair on the drywall side it would be easier without the corner bead under the tile.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-14-2010, 10:18 PM   #3
Rewards Points: 156
I initially used vinyl corner bead but I did not like the way it sat against the cement board so I ended taking that off and going to the J-bead and I am happy that I did. It looks much cleaner and should be easier to feather the thinset to the corner. Thanks for your help.
Corner Bead Coming Loose bhumeny Drywall & Plaster 4 05-03-2010 08:33 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
