Interior Doggie Door - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 11:04 PM   #1
interior doggie door
we want to install a doggi door or 12" square in interior dry wall (between 2 bedrooms). How do I know if there are any wires or cables, etc?
angellycka is offline   Reply With Quote
Old 05-08-2013, 11:22 PM   #2
Rewards Points: 13,956
Use a dry wall saw to make a hole, just be carefull to not go to deep.
Simple enough to reroute any wiring or just patch the drywall if your not up to that.
Old 05-10-2013, 02:14 AM   #3
Rewards Points: 744
My $20 stud finder, from Lowes, will tell me if there are wires behind the drywall.
Simple to reroute the wires? Uh, sure, if you don't mind removing A LOT more drywall!
Seattle2k is offline   Reply With Quote
Old 05-10-2013, 06:44 AM   #4
DIY staff
Rewards Points: 7,174
Poke a small hole---bend the end of a length of wire---stick it in the hole--spin it and see if it hits any thing---
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
