Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-22-2010, 12:32 PM   #1
Interior Corner Crack
It appears as though there is a crack in the interior corner of one of my walls. It looks like the compound separated from one of the walls and there is a 1/8" gap in the corner now; it is about 10'. How do I repair this? Thanks.
monkeystomach is offline   Reply With Quote
Old 02-22-2010, 01:54 PM   #2
Drywall contractor
Tear out any of the old tape that is loose, re-tape, and finish the corner.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Crack in Cast-Iron Wye sonofthetonsured Plumbing 16 01-15-2010 08:10 PM
3 year old house, new crack right through slab aaronb9 Remodeling 5 10-09-2009 04:49 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 01:07 PM
Crack in Concrete Slab under the Front Door diy4life Building & Construction 4 04-08-2009 10:11 AM
Crack in Concrete/Engineered floor Steph885 Flooring 17 04-16-2008 06:52 PM
