Insulation Between Drywall And Studs - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 05:05 PM   #1
CNMDESIGN.COM
insulation between drywall and studs
Hi all
Adding 2x2s to 2x4s on outside walls for six inch no kraft paper insulation.
Can I use fan board insulation between drywall and studs for vapor barrier and a sound and heat transmission break?
If so, will this add a little R value? Coast not a factor.
CNM Design is offline   Reply With Quote
Attaching wainscoting directly to studs or drywall? mjzraz Carpentry 15 11-03-2012 08:43 AM
How would I replace ceiling tiles with drywall on a ceiling with no studs? weedelf Drywall & Plaster 3 02-28-2011 11:43 PM
Sistering or shimming wall studs for drywall? GSilversVeneer Carpentry 1 11-28-2010 12:41 AM
Replacing drywall, do I need to replace the insulation? RyanD Drywall & Plaster 4 06-11-2009 08:46 AM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 06:07 AM
