Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-04-2012, 08:46 AM   #1
installing gyprock and tile around tub
Does it matter if gyprock on one wall is "slightly" further out than the gyprock on the other wall? T install the tile, does it slightly overpass the gyprock to cover the edge or "lip" of the tub, (so the tile is not "completely" just on the gyprock)?
marypatrick is offline   Reply With Quote
Old 10-04-2012, 02:18 PM   #2
Experienced
Jackofall1's Avatar
Hello Mary and welcome to the best darn DIY'r site on the web.
It is difficult to read the question you have posted. Pictures of the area in question would be very good to give us an idea of what is happening.
If read (what I can read) correctly you are going to attempt putting tile on top of gypsum / drywall. This is not a good idea and will only lead to problems down the road.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
ToolSeeker (10-05-2012)
Old 10-08-2012, 11:55 AM   #3
Stuck in the 70's
Blondesense's Avatar
Your intro post makes it sound as if you are using gypsum products in the shower.
Bathroom Adventure
A shower surround should be waterproof before any tile goes up. With only one exception, gypsum products cannot be used in a shower. You might give us a rundown on what steps you are planning.
Old 10-09-2012, 11:27 PM   #4
Contractor
Dan101's Avatar
Can you post pictures?
Dan101 is offline   Reply With Quote
