Installing Durock Concrete Backer Board For Tile - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 08:16 PM   #1
Installing Durock Concrete backer board for tile
I need help in installing Durock backer board around my tub. Can anyone give me some advice , especially when it comes to attaching it to the wall in the vicinity of the flange.
Leigh4pe is offline   Reply With Quote
Old 06-07-2011, 06:17 AM   #2
I make love to my walls
Set the durock on the top of the flange not over it. The tile guy will fill the gap with thinset. Reason being if you set it over the flange it will curve out there which you don't want for a flat tile installation.
Arey85 is offline   Reply With Quote
Installing backer board question zrooster99 Flooring 11 01-23-2011 04:32 PM
Greenboard to Backer Board xsmiles23x Drywall & Plaster 3 09-12-2010 08:40 AM
Cement backer board wadeseward Flooring 16 09-10-2010 11:34 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
