Installing Blue Board Sheets - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 01:44 AM   #1
installing blue board sheets
hi new to this forum and would like to know if any one installed blue board sheets to a steel frame home and what fixings used to secure boards. Also what direction best laid on steel frame vertical or horizontal cheers..
trmbla is offline   Reply With Quote
Old 04-20-2012, 11:40 AM   #2
Rewards Points: 1,092
why not spray foam instead? that is done all the time.
Old 04-20-2012, 11:58 AM   #3
Rewards Points: 13,978
Are you talking about sheetrock or foam?
If it's sheetrock then when ever possible install 12' sheets horizontal, install the ceiling first, then the top sheet on the wall. The bottom sheet needs to be about 1/2" off the floor.
Old 04-20-2012, 06:03 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
RE: Sheetrock Installation
You don't state your location. From what I understand, seismic zones require horizontal installation (Tho I am no expert on seismic zones).
Typical commercial installation onto steel, is always vertical with seams staggered on each side of the wall (so that they don't align parallel).
From a residential standpoint, you can install horizontally (same as wood framing).
However, there are some specific aspects (methods) to installing on steel that adds to the ridgidity of each wall segment.
Make sure that you use self-tapping fine thread screws. You can also use drywall or panel adhesive if you prefer to.
- Build Well -
Old 04-20-2012, 06:04 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
if your talking about foam you have to install it horizontally so to orientate the ship lap so that water will run down the sheet and out as opposed to in.
for fastening you need plasti -top self tapping screws. the plastic washer on teh screw is what holds the foam in place otherwise the foam will come off after the first bit of heavy wind
woodworkbykirk is online now   Reply With Quote
Old 04-20-2012, 11:41 PM   #6
Registered User
Rewards Points: 526
Well, we're 2 for 2, which is it- drywall blue board for veneer plaster or blue colored insulating board sheathing?
Gary
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Installing Drip Edge (Cap) over Barge Board luvdairish Remodeling 2 07-22-2010 10:13 AM
installing foam board on pitched roof David63 Roofing/Siding 5 04-01-2010 11:36 PM
Blue Board georgetax General DIY Discussions 7 11-11-2005 09:05 PM
