Installing A 77 Lb TV On Drywall Over The Fireplace - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 01:44 AM   #1
Moh
Installing a 77 lb TV on drywall over the fireplace
So I need to install this 77 lb that I have over the fireplace, where it looks like there is only one stud, which is in the middle of the wall where I can't use it for the mount. I have this mount http://www.amazon.com/gp/product/B004R9AUOG and it comes with screw holders for dry wall (or toggle bolts). A video of the mount and how to install it is at http://www.youtube.com/watch?v=dKsaaS1_d4E, around minute 5 is when it describes the drywall installation.
I am just wondering if someone who is expert in this kind of stuff can say this is a safe procedure or not.
Moh is offline   Reply With Quote
Old 10-26-2011, 02:10 AM   #2
Moh
by the way, my dry wall is 0.5 inch. I know about cutting the drywall and installing wood blocks (how much does it cost?), but I am just wondering if the procedure shown in the video is safe and maybe I don't need to go through the trouble of cutting the drywall and then paint and ....
Old 10-26-2011, 04:04 AM   #3
Thadius856's Avatar
Rewards Points: 504
I have a similar TV weight on a (much beefier) mount. I would never in a million years consider trying to hang 77 lbs on a sheet of drywall.
If you are going to cut out drywall and reinforce the wall, the cost is minor. A bucket of joint compound is around $5, 2x4's are about $2.50/8ft and the screws are about $5/lb. The major cost is your time and sanity.
Don't forget that you'll also need spray texture, sand paper, paint and cleaning supplies to clean up drywall dust.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
installing drywall returns around windows titan7 Drywall & Plaster 4 08-26-2010 08:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Installing a Wood Burning Stove / Fireplace ddrowe0217 HVAC 3 11-27-2008 03:48 PM
Would installing Moisture Resistant Drywall Backwards hurt anything? cdcamaro9534 Drywall & Plaster 6 11-01-2008 06:20 AM
