Install Sheetrock Around Pipes Through Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 02:27 PM   #1
Rewards Points: 89
Install Sheetrock around pipes through wall
We are sheetrocking the exterior walls of our laundry/utility room and I need to go around a hose bib penetrating straight out of the wall, as well as a PVC sewage pipe heading to the drain field. I can only see two ways to do this without breaking the pipes, which I'm not going to do.
- Leave the sheet as whole as possible, cutting a slot the diameter of the pipe from the closest edge to allow the sheet to be fed over the pipe. Pro: one less full length joint. Con: large patch needed to entire length of the slot
- Break the sheet at the pipe and cut a semicircle the radius of the pipe at the proper location so the sheets have a vertical seem in line with the pipe. Pro: probably easier to finish and have look good. Con: large vertical seam without the tapered edges.
Any input?
rich_kildow is offline   Reply With Quote
Old 01-05-2014, 04:18 PM   #2
Rewards Points: 13,960
Need to post a picture so we can see what your seeing.
Old 01-05-2014, 06:31 PM   #3
DIY staff
Rewards Points: 7,174
Any input?
None of the above--
Cut the hole in the sheet for the pipe---then cut out a V shaped wedge starting at the hole---this will give you the easiest to install sheet--and easy to block and tape.
I wish I had a picture for you---Mike---
Water pipes through a raised foundation wall jacobbencke Building & Construction 2 03-20-2013 09:32 PM
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
pocket door and wall install eric woodall Building & Construction 2 01-10-2013 04:25 PM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 08:33 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
