Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-20-2012, 07:31 PM   #1
Inside corner tool for 90+ angle
Great forum...learning lots of DIY tips!
Is there a source for an inside corner tool with an angle greater than 90 (or is it less than 90?) I have a knee wall meeting up with a ~45 degree sloped wall that meets up with the ceiling. I've grown attached to my inside angle tool for the standard corners but I'm not good enough to freehand the sloped joints with just my knife.
tndiyguy is offline   Reply With Quote
Old 09-20-2012, 07:58 PM   #2
http://www.all-wall.com/Categories/C...ll-Trowel.html
You are using metal backed tape on that seam right?
Old 09-20-2012, 08:02 PM   #3
Yes I am! Thanks for the info!
Corner bead an inside corner? Firehawk734 Drywall & Plaster 2 05-28-2011 12:56 AM
Taping Inside Angle with Tapered Edges project_guy Drywall & Plaster 2 03-08-2010 07:49 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
What router bit is used to create the inside angle on a window stool? Mikedks Building & Construction 7 05-12-2008 05:43 PM
Baseboard - inside corner Potomac101 Flooring 11 02-16-2008 11:44 AM
