Inside Corner Gap - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 11:05 PM   #1
inside corner gap
I am refinishing my basement. when boarding 2 of the corners my studs were a little off I ended up shaving the drywall in the corner but produced an uneven and somewhat large gap (inside corners). can i simply fill the gap with mud and paper tape as usual or would you recommend using an inside corner bead? thanks in advance
brianford is offline   Reply With Quote
Old 04-22-2011, 10:50 PM   #2
Drywall contractor
Rewards Points: 1,070
Hard to say without seeing. A metal reinforced paper bead may be your best bet to be safe. You can pre-fill with setting compound, flat tape the gap, then angle tape with paper.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Replacing 3-stud Corner and Bottom Sill (56k Beware) TellyDSP Building & Construction 3 03-13-2011 07:28 PM
Framing Support for Inside Corner on L-Shaped Stairwell jsoares4 Carpentry 5 01-24-2011 08:25 AM
Left or right hand crown inside corner? Klawman Carpentry 9 01-08-2010 04:19 PM
First coat on inside corner, need advise.. helpless handyman Building & Construction 6 09-24-2008 01:22 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
