-   -   inside corner gap (http://www.diychatroom.com/f101/inside-corner-gap-102341/)
brianford 04-21-2011 11:05 PM
inside corner gap
I am refinishing my basement. when boarding 2 of the corners my studs were a little off I ended up shaving the drywall in the corner but produced an uneven and somewhat large gap (inside corners). can i simply fill the gap with mud and paper tape as usual or would you recommend using an inside corner bead? thanks in advance
bjbatlanta 04-22-2011 10:50 PM
Hard to say without seeing. A metal reinforced paper bead may be your best bet to be safe. You can pre-fill with setting compound, flat tape the gap, then angle tape with paper.....
