Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-12-2012, 03:52 PM   #1
Inside Corner Crack Repair
The attached photo shows a crack along the inside corner between the wall and ceiling. I don't know what caused it. Can I repair this type of crack permanently by removing all loose material and then laying a thin bead of paint-able silicone along the joint? Thank you for your help.
lkstaack is offline   Reply With Quote
Old 02-12-2012, 04:49 PM   #2
One of the many bad things about texture is there near impossible to do a repair without it showing.
Looks like there may two things going on here, one is the tape is coming loose the other may be truss flex or lift. (not 100 % sure I'm not there.
Your stuck with having to wet the texture down and remove it about 6" cut the old tape out, apply new tape, and three thin layers of drywall mud. And sand it out. Try some spray texture to see if it comes close, Prime and paint.
Drywall Crack Diagnosis lkstaack Drywall & Plaster 7 03-11-2012 10:45 AM
corner bead crack igneous Drywall & Plaster 4 02-08-2011 02:11 PM
outside corner crack igneous Painting 1 02-06-2011 11:03 PM
crack repair help beerdog Drywall & Plaster 6 02-07-2010 05:38 PM
Repair damaged bullnose corner DRCollier Building & Construction 2 07-15-2007 10:46 AM
