Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-16-2012, 10:39 PM   #1
humidity stains on drywall from storage
I have about a dozen sheets of drywall that have been stored in the basement for a couple of years and they have some humidity damage near the bottom side (the basement is dry but i have had two-three mini floods doing plumbing work). The parts that have stains are still as firm as the rest. Is this still usable or should i cut the stained edge?
Old 05-16-2012, 10:59 PM   #2
That's about the last place to be storing drywall.
What colors the stains?
No good way from here to suggest something, if it was mine and it was stained I'd figure it was mold and trash it instead of having to deal with paint issues and spreading mold in a room.
Old 05-16-2012, 11:01 PM   #3
grayish.
but if i cut out the moldy belt near the bottom, i should be fine, yes or no?
Old 05-16-2012, 11:25 PM   #4
Sure looks like black mold to me.
I would toss them in the trash.
Old 05-16-2012, 11:43 PM   #5
but most of each panel is as clean as brand new. why not just cut off the moldy parts?
Old 05-22-2012, 04:40 PM   #6
Hey, the choice is yours. That looks like black mold to me. Fortunately, it just appears to be surface mold (however, I can see the end of the panel, nor the inside of it). Surface mold can be cleaned with bleach, or you can cut the bad part off...just like cheese. On the other hand, drywall is pretty cheap to replace.
Seattle2k is offline   Reply With Quote
Old 06-01-2012, 07:25 PM   #7
Drywall contractor
I agree, if it's basically "sound" and the core is still solid, the choice would be yours as to whether you want to take a chance and try to "clean up" the mold, cut it off and use the rest of the sheet, or just trash it. You may want to go to the EPA website and check out the hazards of mold before deciding.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
High Humidity in Home jamiedolan HVAC 7 07-10-2010 01:27 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
