Humidity - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 10:55 PM   #1
humidity
I am getting the drywall taped and mudded in my new home. I am having very high humidity with it. Is that something I should worry about? My home is on a radiant infloor heating system ((no furnace) The concret is now 3 1/2 months old 6 inches thick. Where there is plastic on the floor moisture forms and now with temperatures at -20C and the extra moisture caused with the first run on tape for the drywall my windows are very wet. Should I stop my drywallers? Or is there something I can do to help get rid of the moisture? I don't want mold problems later.
prin is offline   Reply With Quote
Old 11-22-2010, 10:42 AM   #2
jlhaslip's Avatar
Rewards Points: 1,584
set up a de-humidifier and a fan in the space.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-23-2010, 04:50 PM   #3
humidity
Thanks, I've done that and I also put in a bathroom vent fan in the duct tube that is in place for the range hood. I have not been to the site today but I am hoping it has helped. I hear the deep freeze we have been in will be lifting tommorrow so maybe we can open some windows on the weekend.
Old 11-26-2010, 10:36 AM   #4
Drywall contractor
Rewards Points: 1,070
Aside from any mold issues, your finished job is at risk. Joint compound dries from the outside in. In high humidity, the mud may appear to be dry, but can still be wet underneath. It can in some instances literally take weeks for a coat of mud (especially heavier applications like corners and beads) to dry completely. If not completely dried, you can expect "delayed shrinkage". The compound will finally complete the shrinking process and the joints will be visible. I've seen it happen many times, especially when it's cold AND wet. A dry heat source is the best bet. Unfortunately the "torpedo" type heaters running on K1 or diesel actually put out moisture as they run, so are not the best option. Dehumidifiers and additional drying time is probably the best solution in your case. If weather does permit and humidity is low, definitely open the place up....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Humidity issues chapx HVAC 8 09-25-2009 04:11 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
