Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-29-2012, 09:49 PM   #1
How would you install drywall to the ceiling???
1) Would you use 2 layers (1/2") of sheetrock or 1 (5/8")?
2) Would you add resilient channels (i.e. RC-1) to the joists before installing the drywall? Or would you install 1x3 or 1x4 fir strips perpendicular to the joists?
3) Would you use 1-5/8" or 2" screws or nails? And how close throughout the drywall board?
4) Would you install rockwool/mineral wool insulation to help with sound/noise transmission/reduction?
Thank you in advance!
oodssoo is offline   Reply With Quote
Old 11-29-2012, 11:57 PM   #2
where you doing this? main floor? is there a second floor? in the basement?
mae-ling is offline   Reply With Quote
Old 11-30-2012, 12:12 AM   #3
This is for in the basement.
Old 11-30-2012, 10:14 AM   #4
1 no I would not use 2 layers
2 if your joists are 24"oc just screw 5/8 to the joists
3 1-5/8
4 yes
Now having said that let me ask some questions are there pipes and wiring in this ceiling,including waste pipes. What I'm really trying to say is if there is anything in the ceiling you may have to get to later then drywall is not your best choice. You may want to consider a drop ceiling so you will have access.
The Following User Says Thank You to ToolSeeker For This Useful Post:
oodssoo (11-30-2012)
Old 11-30-2012, 01:36 PM   #5
2 if your joists are 24"oc just screw 5/8 to the joists Do you think the drywall will crack (at the joints) due to the joist movements?
3 1-5/8 Screws - I assume - ???
4 yes
Thank you, ToolSeeker.
The ceiling will be drywall and not drop ceiling. This decision was made in terms of "less basement look" - like the rest of the house.
Old 11-30-2012, 03:59 PM   #6
If you have movement in your joists then add some cross bracing to eliminate the movement. And yes screws.
Old 11-30-2012, 06:45 PM   #7
Solutions (handyman)
You can also use lite drywall which is (the claim) 30% lighter than regular drywall. It is also stiffer an won't give you the potential sag that regular drywallsometimes produces with 24" centers.
Mark Harvey is offline   Reply With Quote
The Following User Says Thank You to Mark Harvey For This Useful Post:
oodssoo (12-01-2012)
Old 11-30-2012, 07:07 PM   #8
the sheets are lighter and a bit more brittle and rated for 24" centers. before the ultra came out there was 1/2" sag resistant drywall for ceilings. your doing the basement ceiling and most of the time the floor joists are 16" centers and any old 1/2" will do the trick.
princelake is online now   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 12-01-2012, 01:08 AM   #9
Thank you!
I have elected to go with the followings:
1). Ultra lite 1/2 single layer
2). Resilient Channels perpendicular to the joists (24" oc)
3). 1-5/8" fine thread screws
4). Roxul Safe & Sound insulation
I should be able to share with you the outcome of this assembly... Once all is done!
Old 12-01-2012, 10:19 AM   #10
bbo
Thank you!
good luck, what I am in the process of doing:
1) 5/8 fire rated - 2 layers with green glue between and GG noise sealant around
2) resilient channel though I went 16 oc even though the joists are 16 oc, your method is good
3) screws to make it through and grab the channel are all thats really needed.
4) I went with the denim insulation since it was on sale and I am always willing to try new things.
I did find a good spec sheet for guidelines on resilient channel, maybe it will help you as well.
http://www.phillipsmfg.com/techspec/...stallation.pdf
I'm a little over half done and very happy so far. I have my work office in the basement and what I hear for voices above me now only come through the unfinished area. the extra mass also helps to deaden the clomping that we all know kids are great at too.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 12-01-2012, 03:41 PM   #11
sounds good! screw the resilient channel with coarse thread screws and when screwing the drywall to the channel use the fine thread!
Old 12-01-2012, 04:48 PM   #12
i actually used deck srews to install the RCs... the drill bit works a lot better than the normal phillips...
Old 12-01-2012, 05:38 PM   #13
ya i'll never understand you americans and your phillips screws. the canadian red robertson is a far more superior screw head
Old 12-01-2012, 11:58 PM   #14
bbo
drywall is not that hard.
The Following 2 Users Say Thank You to bbo For This Useful Post:
mae-ling (12-02-2012), ToolSeeker (12-02-2012)
install ceiling box for fan while drywall is off collegetry Electrical 30 02-12-2012 10:17 AM
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 05:54 PM
hanging ceiling drywall in a basement charlie bob Building & Construction 4 03-11-2011 10:49 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
