How Would You Finish This Ceiling If I Removed The Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-08-2014, 10:15 PM   #1
Rewards Points: 32
How would you finish this ceiling if I removed the wall?
traditional plaster walls with an arched ceiling transition. However, I want to remove a wall to incorporate a narrow hallway into the room.
The problem is, the hallway ceiling is just a traditional 90 degree ceiling joint...
so if I remove the wall... how do I blend the different ceiling joint profiles?
I dont want to remove and refinish the other 3 wall joints and I dont have the skill to extend this style into the hallway.
my prevailing thought is to leave the top foot of the wall to retain the ceiling transitions as is... obviously would cast doubt on the illusion that this should be 1 room.
Anyone have a better idea?
left is the hallway, right is the other room ceiling transition
How would you finish this ceiling if I removed the wall?-wp_20140323_001.jpg   How would you finish this ceiling if I removed the wall?-wp_20140508_001.jpg
bauerbach is offline   Reply With Quote
Old 05-09-2014, 09:27 AM   #2
joed's Avatar
Rewards Points: 12,008
Cut the wall off below the crown molding and leave a small beam look across the room.
Old 05-15-2014, 03:39 PM   #3
How high are the ceilings? I would suggest styling it like a really wide doorway. Look up "wide doorway" on google images and you'll see what I mean.
JamieH4 is offline   Reply With Quote
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 11:25 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
wall with coved ceiling hornbup Carpentry 5 12-05-2010 08:28 PM
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 09:51 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 07:18 PM
