How To Use Drywall Joint Tape? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 03:37 AM   #1
how to use drywall joint tape?
i want to know how to use the drywall joint tape. any one know the steps or process.
Show me the link or picture about this, it would be better, thanks
kelly89 is offline   Reply With Quote
Old 05-31-2013, 07:58 AM   #2
Rewards Points: 13,300
http://www.thisoldhouse.com/toh/how-...410343,00.html
This video should help.
Keys to a good job, thin layers not just blobed on, no sanding between first and second coat, just rub the drywall knife over the surface to knock off any high places. Do not use web tape, use paper tape.
Old 05-31-2013, 08:39 AM   #3
Rewards Points: 93
Take a look at the post below, by Willie T. I found it extremely helpful.
First time taping - Tape has air under it
leungw is offline   Reply With Quote
The Following 2 Users Say Thank You to leungw For This Useful Post:
ToolSeeker (05-31-2013), Willie T (06-01-2013)
Old 05-31-2013, 02:57 PM   #4
Rewards Points: 626
well you can follow the advice of this guy. Myron that drywall guy.
Or you can buy one of these little handy tools.
Best of luck with your project.
Nailbags is offline   Reply With Quote
Old 06-01-2013, 10:32 AM   #5
Rewards Points: 5,974
That tape buddy does away with one of the big problems of DIY taping and that is applying too much mud. Don't like the piecing short strips though.
Old 06-01-2013, 10:02 PM   #6
Roofmaster
Rewards Points: 2,172
The key to proper taping is in the mud. You have to temper the mud with a full cup of warm water, and mix it with a large mud mixer till it is nice and creamy. If you are using paper tape, make sure to buy perforated. Buy Goldblatt tools. A six inch knife, and a 10 inch knife. You put a skim coat on the joint. and fully bed in the tape with the six, and remove any excess with the ten. Then let it dry. The biggest mistake you can make is to use the mud straight, the second is to overwork the mud.
I just watched the guy in the Utube video. A drywall pro would laugh himself silly watching that guy. He dosen't know squat about taping, hanging or fastening drywall.
Old 06-01-2013, 10:51 PM   #7
Rewards Points: 626
which you tube vid? Myron Ferguson that dry wall guy? who uses a hawk and knife? or the tape buddy? Because if you say Myron. I would like to know how many books DVD's and Home improvement shows you have done. That guy can sheet rock circles around 90% of people.
Old 06-01-2013, 11:22 PM   #8
Old School
Willie T's Avatar
I WILL give this Myron guy credit in that he knows enough to either set those corner studs out some (I prefer 6 - 8 inches), or to use corner clips (best). AND he also knows enough to hang the top sheet first. You'd be surprised at the number of videos floating around that say to hang the bottom board first.
And I LOVE that corner bead hopper he pushes.
Willie T
Old 06-01-2013, 11:27 PM   #9
Old School
Willie T's Avatar
I'd go careful on using some of these "shows" to prove a guy's knowledge. Bob Villa is well known, but a bar of soap would give him a run for his money where construction knowledge is concerned.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
ToolSeeker (06-02-2013)
Old 06-02-2013, 09:25 AM   #10
WHY, WHY, and WHY and what about the video did you find funny. I'm a drywall guy and I didn't see anything.
1. If your mixing a 5 gal bucket of mud use about 1 qt. of water and it doesn't matter if it's hot ,cold or in between. It will be room temp before you can use anyway.
2. In what way would perforated tape be an advantage. It's thicker whice makes it harder to cover, if not careful can still see the holes after 3 coats.
3. Goldblatt tools are about as low end in drywall tools as you can get. There are so much better such as Hyde, Advantage, USG, Marsheltown, just to start. one I thought was pretty good was Kobalt from Lowe's.
Old 06-02-2013, 11:57 AM   #11
Rewards Points: 4,792
This is false. That is not "the key" to proper taping. There are numerous more important things. Yes, it's recommended to mix the mud, and it might be recommended to add a little water depending on the consistency as it comes (perhaps you haven't used many different brands of compound.) And it certainly isn't necessary to mix it with a large mud mixer - there are other ways, especially depending how how much you have to do.
Why? There is certainly no need to do so.
Why?
What is commonly referred to as a "skim coat" would definitely be too thin for a tapered joint.
As you can see in the video, bedding and removing excess are easily accomplished with 1 tool and one motion - with the 6.
Then let it dry.
OK, letting it dry. You got that one right. Thanks for that important tip.
Those 2 things are not even close to the biggest mistakes you can make with drywall, especially with the first coat. Not mixing the mud is one of the more overlooked things though.
If everyone taped like that video, then it would improve upon 90% of the drywall jobs in this country. I don't doubt that a lot of drywall "pros" would laugh at a lot of silly things, but then when talking about that group, we're really not talking about mostly rocket scientists, are we?
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Nailbags (06-02-2013)
Tags
drywall
Drywall tape?????? All thumb's Drywall & Plaster 1 06-24-2012 08:42 PM
Best way to tape uneven butt joint Firehawk734 Drywall & Plaster 4 05-31-2011 11:42 PM
painting my bedroom -- found drywall tape peeling? 19mquinn79 Painting 2 03-10-2011 08:59 AM
drywall transition joint ? tigman Building & Construction 0 02-20-2010 04:52 PM
Tape drywall joints before painting? mcraenz Drywall & Plaster 7 11-19-2009 07:28 PM
