How To Trim A 6" Circular Permanent Hole In Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-09-2014, 06:20 PM   #1
Rewards Points: 1,062
Question
How to trim a 6" circular permanent hole in drywall?
I need to make a 6" circular hole in a wall that goes between a room and a walk-in closet for a portable air conditioning pipe. It is in a basement and the pipe needs to be exposed spiral (like in a commercial application) because I don't have room for soffits (ceiling low + other space issues) and I want to be able to take it off for painting etc. The framing is regular 2x4 studs. So I would have a 6" hole on the room side sheet and one on the closet side. I would prefer if it were not just a hole in drywall, however exactly cut, but if there was some sort of insert inside it that trims it nicely.
Any idea if there is a ready product like this or that can be ordered and, if not, how would I go about fabricating one? Imagine a round window without the window glass part, just a hole trim.
Old 06-09-2014, 06:42 PM   #2
Rewards Points: 12,852
6-1/4 hole saw and a trim ring for a pot light or a stove pipe.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
amakarevic (06-09-2014), oh'mike (06-13-2014), ToolSeeker (06-09-2014)
Old 06-11-2014, 10:24 AM   #3
Rewards Points: 454
A hole saw is expensive, and something that you would probly never use again. get a circle cutter only a couple bucks at blowes and I am sure you have a jab saw. also it is adjustable so if you ever need to cut a different size hole you have it
scottktmrider is offline   Reply With Quote
Old 06-11-2014, 11:39 AM   #4
cutting it is not a problem, I have a Rotozip. My question revolves around trimming the hole, i.e. which trim to use. If it were just rectangular, I would frame it and use drywall and outer corner beads but I don't know how to make a circular hole with just drywall.
Old 06-11-2014, 12:39 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Somewhere out there there will be a pre-made escutcheon for just such a purpose. Doubt a home center will have one but a commercial HVAC company or drywall installing company, or IT installing company, or Internet company should have such a product. The "light fixture ring" is a good idea.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
amakarevic (06-11-2014)
Old 06-13-2014, 01:46 PM   #6
I've seen the big box stores sell trimming for 4" all the way to 8" circular applications. Not sure if they are meant for columns but it might work for you. Good luck!
slythic is offline   Reply With Quote
Old 06-13-2014, 05:19 PM   #7
DIY staff
Rewards Points: 7,174
I have a wood turner friend that makes me custom rings--(if I can't find a store bought one--)
Old 06-18-2014, 08:11 AM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
I had to make something like that a few years ago. I cut a hole in a piece of plywood, the same size. Then I got a 1/2" x 1/2" vinyl angle. I think it was a piece of outside paneling corner trim. I thumbtacked the starting end inside the plywood hole and used a heat gun to form it into the hole, then trimmed the end. In a few minutes it was cooled and mostly held it's shape. Then used a small bead of construction adhesive to glue it into it's permanent place.
Old 06-23-2014, 09:25 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
10" ceiling medallion, cut the center to fit the pipe
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
amakarevic (06-23-2014)
Tags
drywall , trim
Best way to seal gap in drywall around recessed lighting trim TangledUp Drywall & Plaster 10 06-19-2013 08:53 AM
Proper way to repair oversized outlet hole in drywall Plasmech Painting 16 06-24-2010 12:09 PM
Help - Patching a Hole in a Drywall Ceiling ... njchan Building & Construction 9 04-10-2008 08:56 PM
hole in drywall? econdave General DIY Discussions 11 11-01-2007 06:29 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
