How To Tighten Drywall Screws - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-03-2014, 11:27 AM   #1
Rewards Points: 2,176
how to tighten drywall screws
Someone, at one time, backed into the garage wall breaking the drywall. A 20" square of drywall was cut and screwed over the break. That's fine with me, I don't care.
I've taken the screws out several times. For my own curiosity to see what was behind there, then to show people.
Now I had to take it off again, and I'm concerned the drywall holes are getting loose.
What can I put in holes (on this square of drywall) so when I screw it onto the wall again the screws are tight? I was thinking of filling the 4 holes with spackle or joint compound..........letting it dry..........then screwing the patch of drywall back on.
Startingover is offline   Reply With Quote
Old 01-03-2014, 11:39 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,392
Get some small plastic plugs for the drywall and then screw the panel back on.
Of course you now have me curious as to why you are showing off your hole.
http://www.made-in-china.com/showroo...sion-Bolt.html
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Startingover (01-03-2014)
Old 01-03-2014, 11:41 AM   #3
lol.
I do have some of those plastic plugs. I call them 'molys'. Never thought to use those. I've only used them for when I want to hang something and there's no stud.
thank you
Old 01-03-2014, 11:42 AM   #4
Gymschu's Avatar
Rewards Points: 930
SO, maybe it's time to properly patch that area with some tape and mud…….that is, unless you need access to that area behind the drywall for plumbing, etc. If that's the case, just use longer screws or move the screw holes up or down so you are hitting "new' wood. Sometimes putting toothpicks or golf tees into the holes will give more bite to your current screws. Spackle won't work because even though it's hard when dry, the screws will just push the spackle up and out of the way.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 01-03-2014, 11:53 AM   #5
gymschu,
proper patching on this big an area is beyond my capabilities. I'd be in tears and overly frustrated cause I know my limitations. Maybe someday when all the painting interior and exterior is done?
These screws don't hit wood, just the drywall on the wall. But I could move them. I don't plan to get behind there.
thanks
Old 01-03-2014, 12:10 PM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
delete:
carry-on
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-03-2014, 12:17 PM   #7
Oso954's Avatar
Rewards Points: 1,284
Plastic anchors are not Mollys.
This is a molly bolt.
Oso954 is online now   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Gymschu (01-04-2014), Startingover (01-03-2014)
Old 01-04-2014, 10:05 AM   #8
Rewards Points: 236
a larger piece of drywall ...
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Startingover (01-04-2014)
Old 01-04-2014, 12:10 PM   #9
MT Stringer's Avatar
Rewards Points: 254
If it was me, I would fix it and be done with it.
Clean up your hole to make it square or whatever.
Cut a couple of boards that will fit into the cavity and screw them in place. leave some of the board exposed in the opening.
Cut a new piece of drywall that will fit nicely into the opening.
Screw the drywall to the boards you previously installed.
Tape over the cracks and then apply some mud to patch the area. When the mud is dry, sand it down and apply a thinner coat over the area. Sand and paint.
Done deal.
Notes: I see small drywall for this very type of repair work for sale at Lowe's all the time. You can also buy the mud in a smaller container complete with a plastic spatula to do the repair work.
After all, it is in your garage, right? It doesn't have to be perfect. :-)
Lots of how to do its on You Tube
MT Stringer is offline   Reply With Quote
The Following User Says Thank You to MT Stringer For This Useful Post:
Old 01-04-2014, 12:48 PM   #10
Rewards Points: 4,796
If I had to use an anchor, I'd use one of these.
http://www.howtospecialist.com/wp-co...ll-anchors.jpg
Not one of these
http://www.homedepot.com/catalog/pro...003367_400.jpg
You don't want something that expands. I'd cut it off at 1/2", then screw directly through it into the wood stud. That way you have something solid to hold the screw and solidify the drywall, without expanding and trashing the damaged drywall further.
If needing access, wouldn't this be a lot better?
http://images.meredith.com/diy/image...SCP_163_11.jpg
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 01-04-2014, 01:45 PM   #11
Mt Stinger, someday, when more pressing matters are taken care of I will try fixing the hole. It shouldn't take a genius to do it and like you said, 'it's my garage.'
jeff,
This entire house has been a learning experience. I like the photo of the first link you sent. Thanks.
My main concern for patching this is bugs. It's Florida so lizards find a way in and an occasional big spider. I won't need to get in there.
After having a demanding office job, I enjoy fixing things and working at my leisure on this house..................which is a good thing. What continues to surprise me is the women who don't even try to fix things themselves.
Old 01-04-2014, 02:43 PM   #12
Gymschu's Avatar
Rewards Points: 930
These do wonders if the hole is not too big.
Old 01-04-2014, 03:20 PM   #13
gymschu,
I've used those. They turned out well but took a lot of sanding. This house had outlets all over, for land lines. I left a few, but covered some. There's even one on the porch. I only use a cell.
Old 01-16-2014, 07:46 PM   #14
Rewards Points: 153
I have done this and its pretty effective. Cut the hole perfectly square and your new piece of sheetrock to fit. Grab a 1x4a few inches wider then the hole. Put it inside the wall and then using screws, grab the screws with the old sheetrock. Then screw in your new piece into the hole. Then fill the sand etc. Repair is super strong. IN your case you may want to use 2 1x4's or even 3 horizontally.
cloves is offline   Reply With Quote
drywall + P&L screws ? Fix'n it Drywall & Plaster 3 07-26-2012 10:35 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Drywall Screws Rusting? rick112 Drywall & Plaster 17 03-29-2011 10:57 AM
