How Should I Proceed? (Pics Inside) - Drywall & Plaster - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-16-2010, 11:18 AM   #46
Rewards Points: 36
llckll, plan where you want your splice box before you go to HD.They sell most cables by the foot although for 12/2 you can by smaller rolls than 50 feet.Hopefully you dont have to go back to the panel.And do pick up a test meter.
daveb1 is online now   Reply With Quote
Old 01-16-2010, 11:20 AM   #47
Love for Construction
<*(((><'s Avatar
It would be very helpful in helping your figure out this situation if you could tell us whether the power from your panel to this outlet box comes from underneath, or if it comes through the wall. That would provide a starting point as to how to move the electrical box from the baseboard.
An electrical meter as was suggested by someone else can be had for ~$10 and would help determine where the source of the power is coming from.
Another question is have you determined which breaker controls this circuit and what else is on this circuit?
Figuring out some of this information will help people solve this situation with you.
<*(((>< is offline   Reply With Quote
Old 01-21-2010, 02:04 PM   #48
Just to give You some other ideas,if it is possable,can You attach some round duct to the present one,extend it into the room and put in Floor registers. This would clean up the wall nicely. If this would help then you could cut about a foot of the wall out to gain access for any wiring.Then You could finish with new base.
antlerdancer is offline   Reply With Quote
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 10:00 AM
The "Unscheduled Kitchen/Bath Remodel" <--dead cat, mold, & shoddy work (MANY PICS) perpetualjon Project Showcase 20 07-10-2009 12:22 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Deck - 45 spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 10:28 AM
This is bad, right? (pics inside) dalesd Roofing/Siding 8 02-16-2006 08:33 PM
