How Should I Proceed? (Pics Inside) - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 09:04 AM   #16
Rewards Points: 154
I plan on going to Home Depot during my lunch break. Here are the items that I am going to pick up. Please let me know if I am missing anything.
- Joint compound
- Drywall tape
- Register boot
- Register overhead panel
- New base moulding
I should mention that I have extra drywall at home.
llckll is offline   Reply With Quote
Old 01-15-2010, 09:10 AM   #17
Rewards Points: 154
Also, I was going to pick up a new circular saw blade to cut straight across the drywall or should I just use the current one that I have? Drywall isn't that hard. The one I have now might be 18 or 24 tooth. I forget.
Old 01-15-2010, 09:59 AM   #18
Rewards Points: 20
A circular saw will make a LOT of dust and leave a very ragged edge to tape your new drywall to.Not to mention nicking electrical wires.Just use a razer knife and a straight edge and cut all the way through the existing drywall.Might take several passes with the knife.
daveb1 is offline   Reply With Quote
Old 01-15-2010, 10:02 AM   #19
Rewards Points: 154
Some areas of the drywall where I plan to cut across horizontally has plaster over it. About 1/8" thick. I guess I will have to buy a better quality razer knife. Don't want to deal with the dust.
Old 01-15-2010, 12:37 PM   #20
[quote=GBR in WA;383043]I'd get a pro HVAC guy in there to fix your transition from round pipe to register boot. It appears to be a large void next to it that would feed cold air in from the basement/crawl that would severely temper the air supplied from the furnace. He would also know the size of register to maintain your balanced system.
I would try to fashion transition myself rather than pay someone to snip tin. I would also clean up the space and add the decorative register for sure--nice touch!
However, what's with the outlet and the pho/data jack on the floor-is that code? Eye sore!! Whetether or not IMHO its unsightly and needs some attention. Why not take extra steps to move up behind the behemoth screen?
I'm just sayin'
Han'D' is offline   Reply With Quote
Old 01-15-2010, 02:03 PM   #21
Rewards Points: 154
So I got everything I needed at HD. I bought a new boot register along with a 90 degree elbow transition.
My plan of attack is to cut out drywall a little past the studs on both sides.
Old 01-15-2010, 02:21 PM   #22
Rewards Points: 154
I'm just sayin'
Definite eye sore! It was like that when I bought the house. I plan on definitely cleaning that up!
There is a jack behind the TV on the other side of the wall. I run my wires through to the other side with a cable management plate.
Old 01-15-2010, 06:04 PM   #23
Rewards Points: 20
You will want to cut your drywall down the centre of the stud so that you can screw the existing and the new tight together.By plaster did you mean lathe and plaster or drywall mud?Dried mud will cut with a knife.Once the drywall is off you could use a chisel on any lathe and plaster in behind.You would then have to shim the studs to get your new patch to the same height as the existing.Or maybe some 5/8 ceiling board.
Old 01-15-2010, 10:15 PM   #24
Rewards Points: 154
How should I proceed? (updated pics)
Ok, making some progress and isn't hard at all up to this point. I'm thinking cutting the drywall will be the biggest pain.
Also, I covered the black/white separately with wire nuts. I know this may not be code, but is this safe to do or will it spontaneously combust when I turn the breaker back on?
My dog keeping me company.
The vent is right there so I just need one more elbow extension and I should be good to go.
Old 01-15-2010, 10:23 PM   #25
Rewards Points: 154
Also the studs are right at the left and right of the hole. 16" inches apart. Are all the studs 16" apart throughout the whole house? Just do that I know where to cut the drywall.
Old 01-15-2010, 10:39 PM   #26
Learning by Doing
Leah Frances's Avatar
llckll - technically speaking you cannot just wirenut those wires and leave them loose in the wall (makes for an ugly surprise for the next HOer, or for you in a few years - there's been a post recently by a guy who thought he remembered that the wires he left in the wall were not energized).
But for pete's-sake, get some tape and clearly label the wire with the breaker number and with a notation of whether it is Hot or not.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-15-2010, 10:42 PM   #27
Rewards Points: 154
So what happened to the guy? Will it spark a fire?
Old 01-15-2010, 10:45 PM   #28
Rewards Points: 154
Unfortunately that breaker controls other outlets.
Old 01-15-2010, 10:53 PM   #29
Learning by Doing
I'm an electrical N00b too, for me, the best way to learn is to read about other's mistakes. electrical issue
Can you trace the BX back to where it meets up with the other parts of the circuit?
Old 01-15-2010, 11:03 PM   #30
It looks like these are accessible from the basement?
If so leaving them in the basement with wire nuts is fine
It will not spark a fire as long as they have the wire nuts installed correctly
You do need an outlet in that wall to meet code
So I assume you are putting it back ?
Studs in newer houses are usually 16" apart, in some cases 24"
Older houses can be 16".....24".....or anything else
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 11:00 AM
The "Unscheduled Kitchen/Bath Remodel" <--dead cat, mold, & shoddy work (MANY PICS) perpetualjon Project Showcase 20 07-10-2009 01:22 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
Deck - 45 spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 11:28 AM
This is bad, right? (pics inside) dalesd Roofing/Siding 8 02-16-2006 09:33 PM
