How Should I Proceed? (Pics Inside) - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 07:54 PM   #1
Rewards Points: 154
How should I proceed? (Pics inside)
Hi all,
Wanted to clean up the area under my TV. You'll see before and after pics. How should I proceed? Cover up the area with drywall to fit and install a small vent cover or maybe replace the entire wall with new drywall?
Before:
After:
The wall above the hole is not even. Seems like someone plastered over it by 1/8" to hide screws if that makes sense.
Any guidance and advice will be greatly apreciated as I plan on continuing work tomorrow and this weekend.
Thanks.
llckll is offline   Reply With Quote
Old 01-14-2010, 07:59 PM   #2
Is that a return or does heat/AC come out ?
Old 01-14-2010, 08:00 PM   #3
Rewards Points: 154
That's where the heat comes out.
Old 01-14-2010, 08:09 PM   #4
Does the vent end there or go up to 2nd floor ?
I'd be inclined to frame the opening out for a large vent
Something antique-e looking
Are there any other vents in the house that size ?
Old 01-14-2010, 08:12 PM   #5
Rewards Points: 154
The vent ends there. That's a good idea, didn't think about that. Getting a vent to cover the area that big that also looks antique-e. After I get new base mouldings. So no need to re-plaster it or put drywall in that area to reduce the size?
Why do you ask if there are other vents in the house the same size?
Old 01-14-2010, 08:16 PM   #6
Rewards Points: 154
only problem is that the wall bulges out a little and what are those metal things on the side? I may just cut that off to make it flush with the sides.
Old 01-14-2010, 08:24 PM   #7
I was curious if there were any other large vents in the house
I would frame out the opening with trim to the size vent that you find
Maybe larger trim to match the new baseboard
I'm thinking a larger vent was there in the past
Is that room colder then other rooms ?
Old 01-14-2010, 08:27 PM   #8
Rewards Points: 154
I'd say it is colder than the other rooms because it's the living/dining room and that's the only vent.
Can you show me an example from the internet about trim around the vent? The vent is kind of wide: approximately 16.5" with a little chipped off on the left side as you can see in the pic.
Old 01-14-2010, 08:40 PM   #9
I was thinking a bigger vent was there which kept the room warmer
If you search you are looking for "antique heat register"
One I saw right off the bat in a Google search (images)
Older style angled out from the wall as seen in the side view
Old 01-14-2010, 08:44 PM   #10
Rewards Points: 154
I'll look some up. Was looking up "heat vents". Didn't know it was called "registers". It'll have to be 15"x18". In your opinion, do you think it'll be too large?
Old 01-14-2010, 08:47 PM   #11
The ones pictured are 15x12"
I'm sure someone must have something close to that size
Old 01-14-2010, 09:00 PM   #12
Registered User
Rewards Points: 5,492
I'd get a pro HVAC guy in there to fix your transition from round pipe to register boot. It appears to be a large void next to it that would feed cold air in from the basement/crawl that would severely temper the air supplied from the furnace. He would also know the size of register to maintain your balanced system.
Be safe, Gary
Old 01-14-2010, 09:02 PM   #13
Rewards Points: 154
I can install the register boot myself. Just looking for a register that big.
Old 01-14-2010, 09:18 PM   #14
Rewards Points: 154
I cannot find a register that big. I think I will just install new drywall in that area. Cut the drywall straight across and install new. What do you guys think? In the process, I will install a new register boot and take out the old metal grill.
Old 01-14-2010, 10:47 PM   #15
jlhaslip's Avatar
Rewards Points: 1,538
good plan.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 10:00 AM
The "Unscheduled Kitchen/Bath Remodel" <--dead cat, mold, & shoddy work (MANY PICS) perpetualjon Project Showcase 20 07-10-2009 12:22 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Deck - 45 spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 10:28 AM
This is bad, right? (pics inside) dalesd Roofing/Siding 8 02-16-2006 08:33 PM
