How To Seal Off Opening In 3 Layers Of 1/2" Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 11:57 PM   #1
How to seal off opening in 3 layers of 1/2" drywall
There is 3 layers of drywall on one of our ceiling areas and there is an opening for a heating register. How can I seal off that drywall so that there is no chance of loose drywall or dust falling down. The area right beneath there is where kids play and there is the heating air that will blow past it. Will spackle stick to the drywall there? Thanks.
djgrant is offline   Reply With Quote
Old 01-23-2012, 12:05 AM   #2
Rewards Points: 14,014
And what happened to the boot where the vent was?
Why not just put back where it belongs.
Old 01-23-2012, 04:03 AM   #3
What are you talking about?
Old 01-23-2012, 04:32 AM   #4
An old Tradesmen
Rewards Points: 7,816
The supply appears to still be above that hole, and not sealed.
Old 01-23-2012, 06:11 AM   #5
the Musigician
DangerMouse's Avatar
I would be far more concerned about THREE layers of drywall falling on the kids than a little dust! I would take the drywall down, ALL OF IT, and put in ONE layer of 5/8" Fire-X. Then replace the register. Leave it closed if you do not need the heat there at that point in time, but leave it there. It was likely designed that way on purpose.
DM
Old 01-23-2012, 06:54 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
You don't need drywall work. You need sheet metal. Looks to me like somebody just rough cut a hole in the duct to supply conditioned air to the room and never finished. I'd line the hole with sheet metal up to the duct, secure it and put a proper diffuser in place. I have to guess that there may be a fire code requirement for 3 layers of drywall. If it's all secure, I would leave it.
Old 01-23-2012, 07:04 AM   #7
Rewards Points: 1,480
What are the chances of all three layers being properly secured? That would require some long screws. Is it possible they just screwed the bottom layer to the next? Glue maybe? Seems odd.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
DangerMouse (01-23-2012)
Old 01-23-2012, 07:59 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
^^ This would be my thought on it as well ^^
Aside from the sheet metal related work, I'd also suggest to leave the drywall where it is. One possible scenerio:
Layer # 1: Looks like older plaster board (original ceiling).
Layer # 2: Could be a lay-over repair of the old ceiling.
Layer # 3: Could be an addition of Fire-rated sheetrock to accommodate current code requirements.
- Build Well -
Old 01-23-2012, 08:03 AM   #9
Yes, they likely would have used longer screws + potentially glue - if it was professionally installed.
Example: If all 3 layers are 5/8" = 1-7/8" + 3/4" = So 2-1/2" screws would work/hold.
(When we had a dedicated drywall work-van, we always kept all kinds of lengths & types of drywall screws from 1" to 4" to accommodate any remodeling project).
FWIW: The average weight of 1/2" GWB in interior residential construction generally weighs about 1.6 pounds per square foot, so you are looking at about 5 pounds SF or less for the ceiling weight.
- Build Well -
Old 01-23-2012, 08:27 AM   #10
You missing your ceiling register box and defuser.
http://www.indoorcomfortsupply.com/c...&category=MRBX
Old 01-23-2012, 09:46 AM   #11
the Musigician
If so, that sure is an awful lot of sheetrock to hang on a ceiling to meet fire requirements! scary stuff....
DM
Old 01-23-2012, 10:39 AM   #12
DM
Not that scary.
I'd reckon to say that Horsehair plaster & wood lathing weighs more per SF than 3 layers of conventional 1/2" GWB per SF.
I could be wrong, but that stuff is dang heavy, if not heavier.
- Build Well -
Old 01-23-2012, 12:52 PM   #13
The extra layers of drywall were simply added to make the ceiling flush with another spot that was 1 inches lower.
"Maintenance 6" is correct, someone rough cut a hole in the duct and put a hole in the drywall but didn't put any other sheet metal like they probably should have. During our renovations, the 2 extra layers or drywall were added.
I don't think I have the skills necessary to do the sheet metal work. Is it really important to do the sheet metal? It seems to provide lots of air as is. Is there any other concern?
Old 01-23-2012, 12:59 PM   #14
There is no skill involved in this one, if you can turn a screw driver and close up a wire tie you can do it.
All your going to need is the size of the hole to go buy the ceiling adapter.
Old 01-23-2012, 01:08 PM   #15
So it sounds like you're saying I just get an adapter and the adapter is screwed to the duct?
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Two layers of faced drywall in attic - remove one or both? TomServo HVAC 1 04-21-2010 06:49 AM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
