How To Replace A Section Of Drywall? (Total Newbie) - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 12:26 PM   #1
Rewards Points: 184
How to replace a section of drywall? (Total Newbie)
Here is the section which I cut out after it was damaged by water:
What are the steps to repair that after I remove the baseboard and cut a piece of drywall the same size as the hole?
Then to I glue it in? nail it in?
Then spread is it joint compound over the crack? Sand and paint?
TIA
abefroman is offline   Reply With Quote
Old 07-28-2010, 06:07 PM   #2
DIY staff
Rewards Points: 7,174
Nasty patch for your first fix------You will need--a small roll of paper tape--the patch--
A good 6" steel blade and maybe an 8" or 10" blade. A sanding sponge.
Pull the small section of base board- screw the drywall to the studs--add a bit of scrap blocking to the right side if the stud is to narrow.
I suggest a bag of easy sand 20 (20 minute set)--Mix a small batch--pack any voids--add a line of mud on both sides of the corner--cut a piece of paper to length--fold embed it into the mud with your 6" knife press gently you want to leave enough mud to hold the paper.do the same for the top seam.
Clean your tools--get a cold drink--check your work in 20 or 30 minutes---
Using the 6" blade--knife off any globs,boogers and high spots----Then add another thin coat using the 6"blade---clean tools -wait--knife off boogers--add another thin coat with the wider blade--
That's about it--sand if it looks O.k.--add more coats if not. If the job were larger I would have suggested a different mud.---Mike---
Old 07-28-2010, 06:22 PM   #3
Rewards Points: 184
When pulling off the base boards I found some more spots of wet/weak dry wall, so I cut that out, and not have about 10 times that area to do, 8 spots total.
What would be the best mud for that? Is the premixed stuff any good?
Old 07-28-2010, 06:49 PM   #4
DIY staff
The premix is fine--much easier to sand--
If you have a bunch to do--switch to 45 or 90 minute bag mix to fill voids and embed the paper--
Then the bag mix for the first coat --switch to the blue top bucket mix for the final top coats--
much easier to sand-however it take 12 to 24 hours to dry--use a fan----that is why I suggested the fast setting stuff when you had only one small patch.--Mike--
Old 08-01-2010, 12:17 PM   #5
Drywall contractor
Rewards Points: 1,070
Yep, setting compound saves time. And if you use mesh tape on any repairs it is a must for at least the first coat. OP will need paper tape as oh'mike stated as it's an inside corner and the method is dead on....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Roof Leaking - Do I Need to Replace Drywall? dombrorj General DIY Discussions 5 06-21-2010 06:10 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
total newbie, saying hi! Asma Introductions 1 12-05-2008 06:36 AM
plastering or drywall section? Plaster Brokers Site Help and Suggestions 0 07-27-2007 10:26 PM
