How To Remove Pop Corn Texture From A Ceilng. - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 05:33 PM   #16
Drywall contractor
Rewards Points: 1,070
In an unoccupied space, the "wet and scrape" method is probably the easiest. I figure by the time you do all the masking and set-up to "wet and scrape", using a scraper and power sander with a good vac system is pretty much a "wash". I use the vac system for all repairs to reduce dust anyway. When I replied, I was answering more along the lines of a painted surface, but personally I would use the same method either way. I know a lot of people use the "wet and scrape" with great success. And yes, the joints will need at least one skim coat....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
paint removal , textured ceiling
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
drywall texture time.. any recommendations? SKINNY Drywall & Plaster 6 10-23-2008 11:42 PM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
