How To Remove Plaster/Lath Without Damaging Adjoining Walls? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 05:44 AM   #16
Plaster $ lath
Plaster is a mess when you cut it by mechanical means. No matter how good you seal stuff up the dust will get all over the house.
Go get a one time use cheap wide wood chisel. Take your time and cut where you need to. Crack the remaining plaster with a hammer and put it bags or boxes immediately.
Then use a small saws all to cut the lath and pry it off with your claw hammer. If you go nuts just smashing plaster and lath you will have a mess to clean up that will take quite a long time. Be neat about removing it and you will save allot of time in the long run.
Take your time and be clean.
Use a drop cloth, break the plaster off the lath first, and clean it up.
Then just pry the lath off and bundle it up.
Bob
Hourglass52 is offline   Reply With Quote
Old 01-19-2011, 04:10 PM   #17
Handyman
Rewards Points: 512
A circular saw will be EXTREMELY messy and dusty. Also you can't get close into corners where the ceiling, floor and walls meet.
canadaclub is offline   Reply With Quote
Old 01-20-2011, 12:06 AM   #18
Rewards Points: 978
thanks for the insight gentlemen. this is going to be tough then...i am not worried about the mess as much because i am replacing the carpet afterwards, but i would like to contain dust as best as possible.
federer is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
remove staple without damaging NM DIYGST Electrical 4 01-04-2009 09:01 AM
How to remove a technique I did to my kithen walls ekolp Painting 5 12-31-2008 04:55 PM
How to remove adhesive from painted walls before painting buffnrie Painting 3 04-27-2008 01:14 AM
help! my walls are troubled donnamarie General DIY Discussions 5 08-29-2007 12:08 PM
