How To Remove Drywall Plaster From A Wool Rug? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 02:47 PM   #1
How to remove drywall plaster from a wool rug?
Anyone know what would work well for removing drywall plaster that is dried onto a wool rug? I would like to remove the plaster and also preserve the rug and its colors.
Iron Petunia is offline   Reply With Quote
Old 01-09-2012, 03:51 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
If you mean drywall compund, I've used a curry comb, like a horse groomer uses. Rub it in circles on the carpet. When all the crumbs are broken loose, vac them up and finish up with a damp rag. No need to use any kind of detergent that might affect the carpet. Drywall compound is pretty inert and water based.
Old 01-09-2012, 06:09 PM   #3
I second the above post... drywall compound if that is all it is? is water soluable, lots of water and circular motion
Lr
luckyrabbit is offline   Reply With Quote
Old 01-09-2012, 06:14 PM   #4
Ok, I will give that a try. Thank you!
On a side note -- how toxic is it to breathe drywall dust?
Old 01-09-2012, 06:21 PM   #5
Old School
Willie T's Avatar
Sorry. You likely won't live past 103.
Willie T
Old 01-10-2012, 08:58 AM   #6
A Little Of Everything
Rewards Points: 1,364
It's not toxic, but your nostrils, sinuses, and lungs are not going to like it (if that makes any sense).
DrHicks is offline   Reply With Quote
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
From plaster to drywall - window frame woes ink Carpentry 21 05-23-2010 03:19 PM
plaster or drywall? Allnewtoday Drywall & Plaster 7 04-12-2010 09:45 AM
drywall mixed with plaster - do I need to tape? Windows Drywall & Plaster 4 03-09-2010 04:02 PM
Integrating a plaster wall with drywall? britt_schaeffer Drywall & Plaster 4 09-23-2009 02:45 PM
