How To Properly Seal Cuts And Damage To Drywall Paper? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 01:57 PM   #1
Rewards Points: 14
How to properly seal cuts and damage to drywall paper?
I just finished hanging drywall for the first time on a partition wall that I built.
But, some of the screws caused the drywall to buckle and the paper bulged up and tore in those areas.
I cut away the loose paper as best as I could, but now there are several small spots that have no moisture
protection because of the missing paper where the rock is exposed. Now I'm worried about what will happen
when I mud and tape these areas (some are located in tapered joints, others are in the middle of the wall).
I didn't know what else to do, so for now I applied some BIN Shellac primer from a spray can in the hopes
that it will help seal the area from the moisture in the pre-mix mud.
1. What's going to happen when I apply the pre-mix mud to those spots and the moisture attacks the exposed rock?
2. Or should I just make several more coats with the BIN before mudding?
3. I also read about Gardz, but from what I gather that only works on torn paper not exposed rock, right?
Thanks, I also included a few photos of the worst spots.
maxforwardspeed is offline   Reply With Quote
Old 08-23-2012, 04:35 PM   #2
Rewards Points: 13,300
The right way would have been to cut any loose paper and just a light sanding to get rid of any high places then go over it with mud like you would any screw. No painting it first.
Old 08-23-2012, 08:45 PM   #3
Rewards Points: 14
Can't I just sand it now, then re-apply the primer/sealer to the area after it's smoothed a bit better?
Old 08-23-2012, 08:49 PM   #4
It's going to take at least two coats of drywall compound, sand it, add another coat if there's still flaws, then prime and paint.
Paint will not fix flaws in the finish.
Old 08-23-2012, 11:09 PM   #5
Rewards Points: 14
Ok, thanks Joe. It was my understanding that the primer seals the nearby paper and protects it from moisture damage (swelling) when the mud is applied. But it sounds like you are basically saying to not be concerned with that step at all? Just go for the mudding and worry about the finish later?
Old 08-24-2012, 12:20 AM   #6
If I have torn paper I will typically scrape and sand it, then prime before mudding. (to prevent bubbling in the mud later on) However for areas as small as in that pic, I wouldn't worry too much. Just make sure your screws are set to dimple below where the papr would be. One coat of primer is fine before any mudding, it's just to seal it.
chrisBC is offline   Reply With Quote
Old 08-24-2012, 10:05 PM   #7
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Max, I would definitely put another screw in a couple inches away from any screw that has broken the paper.
Once a screw goes beyond the paper it has lost all of it's hold strength.
Sir MixAlot is online now   Reply With Quote
Old 08-24-2012, 10:58 PM   #8
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
Im shocked out of all these posts, you are the first one to even say this...
Do as the Sir says. If you break the paper of the drywall, that means you have driven the screw in to far. it looks as if you used just a regular screw gun with out any special tip. each screw that is past the paper will not hold the drywall properly and will create problems. I dont see the paper being torn as a problem if it doesnt peal up from being ripped. If it does peel, then you need to do a little extra work.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 08-25-2012, 12:17 AM   #9
Rewards Points: 14
Ok, question on that: Those screws in the photos actually appeared the same before they were flush with the drywall as they were going in. Is it possible that the torn appearance was created just from the paper curling up where the screw was first "catching" on the way in?
I do have a few screws that I know for a fact broke the paper. They seemed to just let go and give when that happened. Not with these from the photos, they were definitely still biting pretty good.
Old 08-25-2012, 07:46 AM   #10
stoner529's Avatar
Rewards Points: 154
No...a properly set screw never does that.
Old 08-27-2012, 01:33 AM   #11
Registered User
Rewards Points: 5,218
A picture and description of the screws would help. From about 8-10 inches away... Add a pic of the drill tip/attachment.
The paper facing/gypsum core doesn't require moisture sealing as you mentioned in post #1. Drywall is around 30 perms (vapor permeable).
Gary
Gary in WA is online now   Reply With Quote
Old 08-29-2012, 03:41 PM   #12
Drywall contractor
Rewards Points: 1,070
Agree with Sir & stoner. You have cut the face paper. Need to add a screw(s) close to the ones that popped WITHOUT going through the face paper. The drywall is not attached tightly to the framing if the paper is torn and you will have issues with screws "popping" until the problem is resolved. You don't need to prime. What type of moisture "attack" are you concerned about?? If this is in a conditioned space (heat and AC), there's no issue once the board is finished and painted properly......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-02-2012, 06:06 PM   #13
crankcase's Avatar
Agreed, But I would also add to pull out the screw that was driven too deeply. For me any fastener that misses a framing member or not set properly or breaks the paper gets pulled.
crankcase is offline   Reply With Quote
Old 09-02-2012, 09:50 PM   #14
Drywall contractor
Definitely pull any that didn't hit any framing. Those that did will be ok if you add another fastener very close to the one that "popped", not a few inches away. And one above and below is best. If you back out the "offending" fastener, so much the better. It's no big deal with screws. I'm used to nails in wood framing, so pulling is not an option.....
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
