How To Properly Install Vent Grilles So That They Stay In Place? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 11:22 AM   #1
Rewards Points: 37
Question
How to properly install vent grilles so that they stay in place?
I decided to rip out all the old cheap, painted over vent grilles, in my house, and bought pretty antique bronze ones, which according to my measurements, fit exactly into the openings in the drywall. However, none of the grilles wants to stay in. It's not the screw-into-the-wall kind, so they should 'supposedly' just click into the duct work, but the duct work isn't perfectly square and the little plastic holders are flimsy. I am looking for suggestions on the best way to make sure they stay put. Has anyone else run into this issue?
genEus is offline   Reply With Quote
Old 10-27-2010, 11:29 AM   #2
the Musigician
DangerMouse's Avatar
All depends on if you want them removable for cleaning or not I guess....
You can easily GLUE them to the walls, but to remove them to clean inside could be a bit of a problem down the line......lol
DM
Old 10-27-2010, 01:12 PM   #3
(the original)
Rewards Points: 756
Maybe wrap some friction tape around those "little plastic holders" to tighten up the fit and give them some bite.
ratherbefishin' is offline   Reply With Quote
Old 10-27-2010, 06:51 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
Powerful Magnets maybe?
Old 11-10-2010, 03:51 PM   #5
Drywall contractor
Rewards Points: 1,070
Sounds like you may have inadvertently purchased grills intended for floor application, not wall/ceiling. They should have screws to keep them in place....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
gas fire place install couchguy Electrical 4 12-17-2008 11:12 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 09:31 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
