#1 |
How to patch up these small drywall holes in the ceiling?
I wasn't expecting these. I was getting rid of my current kitchen's old lights and putting in a bunch of recessed lights. After I took out the current big ceiling light I found that there are a bunch of holes in there. The biggest one is 1" diameter, the rest are like 1/2".
Also, the center peeling paint looks like original which was from 1957. I assume it's the lead paint. ![]() How to patch up the holes? And what to do with the peeling paint? Thanks! Last edited by htabbas; 12-20-2011 at 11:46 PM. |
#2 |
Scrape off the loose paint and skim coat the area with drywall compound, let dry, knock off any high spots and skim coat again with very thin coat, . Then sand off with a fine dry wall sanding sponge. Then prime and paint.
#3 |
Military Mom of 4
For the lead-paint safety: a nosha approved facemask and gloves - thoroughly vacuum when you're done . . . and vacuum some more.
I've found it best to remove as many items from the room as possible before scraping to ease this cleanup process. But you shouldn't have too much if you're working in a small area.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
#4 |
For those 1" or 1/2" diameter holes, can I just use compound to plug it? Or do I have to enlarge it a bit to use a larger piece of dry wall to plug it?
#5 |
Learning Things Every Day
A 1" hole is nothing. I've patched holes much larger than that. Pack some mud in it, scrape it smooth with a putty knife, let dry, sand, done.
Under Construction |
#6 |
for the question of lead paint find out for sure .lowes and home creepo sells a test kit for about 20 dollars ,easy to use you will know right away.they have a web site and you can find testing video on youtube .with that said i doubt its lead paint .but hey what do i know
. anywho how i handle holes of that size ill use 45 set its a quick setting mud mix with water. but you can use reg. joint compound. ok this is key , as for the holes depress in the holes slightly with the round end of a screw driver or the handle end of your putty knife,only slightly .depending on the size you could just skim over it wait till it dry and skim over it again .also i have tore a small piece of paper towel covered it it the mud balled it up and pushed it in the hole then skimmed over it . your going to have to skim over the perimeter of where the old light was ,a very light skim .if you take your time and sand prime and paint , it will turn out beautiful .for this i would use a high quality washable flat .
#7 |
retired union carpenter
How to patch up these small drywall holes in the ceiling?when you're happy? sand lightly and paint good quality paint. without the tape, when mud is completely dry in say a couple weeks or a month? you'll see a hairline crack all around the hole. as always, just my thoughts. take what helps? ignore the rest! coupe/Larry
as always, just my thoughts good luck....coupe/Larry take what helps? ignore the rest. |
#8 |
If you have any fiberglass tape laying around you can cut a small ball and shove it in the 1" hole. Have had great success with this method and less cracking in the long run.
| Display Modes | |
| Best way to install drywall on uneven ceiling | Fred_ | Drywall & Plaster | 7 | 11-28-2011 09:54 PM |
| How much cellulose can a drywall ceiling support ? | Arky217 | Building & Construction | 10 | 10-29-2011 10:48 PM |
| framing ceiling for drywall | artlover13060 | Drywall & Plaster | 1 | 07-04-2010 11:25 AM |
| Basement drywall ceiling and walls questions | enero | Drywall & Plaster | 6 | 06-05-2010 04:13 PM |
| Best way to patch holes in drywall | CowboyAndy | Drywall & Plaster | 5 | 12-18-2008 12:55 PM |
