How Often Can You Add Water To Mud To Thin It - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 02:37 AM   #1
Renovating My Land Yacht
Rewards Points: 616
How often can you add water to mud to thin it
Silly question......
How often can you add water to mud.....can you add a little each day or will this screw up the setting/holding power?
Using regular all purpose mud in the "omg its a bloody heavy bucket" Its still stinkin hot down here. First day I add water and I can play Picasso but by the end of the second day things are getting a bit stiff (me and the bucket ) Can I add water daily for a couple of days or does this mess with the super secret setting formula.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 09-15-2013, 05:31 AM   #2
Rewards Points: 5,974
You should only need to add it once. You are not using right out of the bucket are you? You should be using a mud pan or hawk, keeping your bucket lid on tight between fillings. And put that piece of plastic on top because this will also keep it from drying out. If it does get still you should just be able to remix it and loosen it up. Too much water will affect the strength of dried mud.
Old 09-15-2013, 08:01 AM   #3
automated tool pro
Rewards Points: 152
helpful tip...if it's taking you more than a day to use up your mud and you plan on using it the next day at the same consistency. Take your 6" knife and sweep clean the sides. Look at that mud. If it's full of crust/dryed mud through it out. If not through it back onto of the rest of the mud in the bucked.....OK...here's your answer. take a could sweeps across the top of the mud to flatten it out. Take a sponge full of water and clean the sides of the exposed bucket sides. thr water in the sponge will collect on top of the mud. what you want is to completely cover the mud with a very fine layer of water. as long as that water sits on top it will be right for the next day. Be sure and put the lid back on of course. Pop the lid off the next day and mix that water into your mud. essentially. you just killed two birds with one stone, your mud has been preserved the best way possible and it's ready to be mixed...........a third helpful tip....whenever you take mud out of the bucket to use, always take it from the center, and by that I mean dig deep down the center leaving and nice layer coating the sides. when you get about halfway into the bucket ThEN sweep the sides clean. by doing this that mud has been preserved, being the sides were never exposed to air. May sound odd and you may get some on you when you dip into it, but your mud has been preserved for use. Use your judgement as the temp is high there, and you may not be able to dig that deep into the center before sweeping the sides clean.
drywallfinisher is offline   Reply With Quote
The Following User Says Thank You to drywallfinisher For This Useful Post:
forcedreno2012 (09-15-2013)
Old 09-15-2013, 09:02 AM   #4
Rewards Points: 236
i just took out a 1/2 full bucket that sat for 10 months. it is perfectly fine.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 09-15-2013, 01:26 PM   #5
Rewards Points: 616
Thanks for the tips. I am using a hawk and not using it straight from the bucket. I have also been cleaning the sides and putting the plastic on overnight....what I have not been doing is covering it while in use.
I will put the lid back on in between and see if that helps. I do re mix it the second day but I guess not putting the lid back on between pulls is allowing it to dry somewhat. I know the walls are drying quickly - heck its 90 degrees here today and no AC
Have gone through 5 buckets in the last week. Its amazing the differences between each bucket. I even got what I am calling a "bingo bucket" weighed a bunch more than the others and when I popped the lid It was jammed to the top instead of being filled to the usual 3 inches from the top. Pretty sad that 3 extra inches of mud in a 12 dollar bucket excites you
Robyn
Old 09-15-2013, 05:26 PM   #6
Bill Kearney
Rewards Points: 1,174
When the job slogs on endlessly you celebrate any the little victories you can get. Good luck!
wkearney99 is offline   Reply With Quote
The Following 2 Users Say Thank You to wkearney99 For This Useful Post:
Fix'n it (09-16-2013), forcedreno2012 (09-15-2013)
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
