How Much Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 03:27 PM   #1
how much sheetrock
How do I figure out how much sheetrock I need to turn my garage into a room.
Cindymoohoo is offline   Reply With Quote
Old 11-04-2010, 08:14 PM   #2
Phoenix
figure out your square footage & then check this site out: http://www.house-flipping-helper.com...alculator.html
Axecutioner-B is offline   Reply With Quote
Old 11-04-2010, 08:19 PM   #3
jlhaslip's Avatar
Rewards Points: 390
For new construction on a 'typical' subdivision home, multiply the floor square feet by 4.
Approximately that much board should be ordered.
Your mileage may vary.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 11-04-2010, 11:01 PM   #4
walls - total linear feet times wall height divided by 32 (assuming you are using 4x8 sheets)
ceiling - Sqf of ceiling footprint divided by 32 (again, 4x8 sheets)
example: 12x12 garage, 8 foot walls
walls = 36 linear feet X 8 = 288 Sqf divided by 32 = 12 sheets
ceiling = 12X12 = 144 divided by 32 = 4 1/2 sheets
total = 17 sheets (18 since they come in pairs)
and get at least a couple extra. its a lot easier to return them later than regret not having enough if you screw up.
so, basically comes out to the same as what jlhaslip suggested (i just need to break it down.)
now, if you have taller than 8 foot ceilings, or wall runs longer than 8 feet, consider using larger sheets (4x10, etc...) as this will reduce butt end seams. might even save some money?
1910NE is offline   Reply With Quote
Old 11-05-2010, 02:16 AM   #5
it's priced fairly similar. 12' boards are about 50% more than 8' boards but it finishes faster. the fewer seams you have the better. use paper tape if you want to avoid cracks. not saying glass always cracks, it's just more likely to than paper even if you have it in hot mud.
racebum is offline   Reply With Quote
Old 11-05-2010, 09:15 AM   #6
I totally agree with this, but have to laugh all the same. I recently added a second level addition, and had drywall ordered/delivered while they could still boom it through an opening in the side of the house. Unfortunately, both myself and another person thought we had a fairly accurate estimate of how much drywall was needed. After I finished hanging it all, I discovered that I (and the other person) had somehow calculated a need for 26 extra sheets of 12' drywall . To this day, I still don't know how I over-estimated by that much, but it was a real treat trying to get it out the second floor patio door and down to the ground level without banging it up so that I could return it. Good luck with your estimates, and using the above suggestions will hopefully get you a fairly accurate estimate.
H8Mondays is offline   Reply With Quote
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 10:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
