How Much Of A Gap Is Necessary - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 04:55 PM   #1
how much of a gap is necessary
We are tearing out our t-bar drop ceiling in the bathroom and we also have to replace our current neo-corner shower stall ... I am looking at putting in a "drywall/ sheet-rock? " ceiling however it will only be 3/4 inch from the top of the wall panels of the new shower stall. The total height of the stall walls from the floor up (base included) is 80 inches... and I need to set the ceiling at 80 3/4". Is there a minimum that I must keep???
I currently have a 77" high shower wall (base included) installed but I can not find a full kit (walls and base) only being 77" high anywhere !!! So, if you have any knowledge of where I can purchase one of these, just let me know that too ... this would make life easier I guess.
Thanks in advance to all for all the help
cvbs is offline   Reply With Quote
Old 03-30-2011, 06:05 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I wouldn't use regular drywall above the shower.
XXX
Old 03-30-2011, 07:49 PM   #3
O.K. and your suggestion would be to use what as a ceiling in the bathroom, Not just over the shower?? and b.t.w. Thanks for the HELP it is MUCH appreciated. Being a novice I am learing as I go .... this would be one for the T.V. shows
Old 03-30-2011, 07:54 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I like to see MR (moisture resistant) drywall used throughout any bathroom that has a shower. Especially over the shower (5/8").
This isn't to say regular drywall isn't used all of the time because it is, but if you have an opportunity to head-off future issues, now's the time to do it.
XXX
Old 03-31-2011, 10:46 AM   #5
i would advise to use the green board on all ceilings and surounds good luck
to deal with the gap have you thought about some type of trim to hide it?
lrobertstoner is offline   Reply With Quote
