How Much Drywall Compound Do I Need - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 07:16 AM   #1
atm
How much Drywall compound do I need
I have 70 sheets of drywall needed for may basement project. I've had different contractors estimate the amount of drywall compound materials I should have and got different estimates.
For 70 sheets of drywall, how much of the 23 KG drywall premix compound boxes should I expect to use (approximately)?
Is there a difference in the coverage if I use the bag 11kg sheetrock versus the boxed drywall premix? does one provide more mudding coverage than the other?
Thank you.
atm is offline   Reply With Quote
Old 04-29-2009, 08:20 AM   #2
Rewards Points: 5,336
I use about 1, 5 gal tub for every 5 sheets.
Ron
Old 04-29-2009, 10:27 AM   #3
Drywall contractor
Rewards Points: 1,070
It depends on the job. If it is cut up into a lot of rooms, you'll have a lot more angles to finish than just one or two big rooms. If there is a lot of corner bead (say for soffits/chases to hide HVAC, etc.) it will take more than just a flat ceiling. Are we talking 70 sheets of 8' or 12' board?? that will make a difference. And I don't use boxes, I use buckets. Buckets have more in them than boxes. The bags contain setting type compound which doesn't shrink as much as ready mix, costs less than a bucket, but doesn't make 5 gallons. If you don't use it all in the allotted time, you have to throw it away. All that said, when I have an average job stocked, I generally order a bucket of mud for every 1000 sq. ft. of drywall and throw in an extra for good measure. Two extra if there's a lot of bead/angles. And this is considering professional finishing. You should get by on 3-4 cans if you're fairly good at finishing. If you're going with box mud, I think it's 4 or 4.5 gallons per box as compared to 5 per bucket. You can do the math.
Ron, I hope that was a typo. 5 gallons per 5 sheets??? You're using waaaaay too much mud, if so...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-11-2009, 01:30 PM   #4
HABSFAN2006's Avatar
Rewards Points: 150
Age old question...
I am going to bump this one back up. Hope someone can help, I am in the same situation presently.
I have 50 sheets, 4x8 to cover for a basement project.
I am working with 20kg tubs of CGC mud, the option was the 23kg boxes like the OP, which also wanted a pound estimate,
The previous answers were given in gallons, and I do not know how much mud weighs per gallon,
could someone please clarify this, maybe we can get an avg. weight req'd per 1000 sq ft? Or, do you contractors use a per sheet estimated weight?
(32 sq. ft)?
Life is an experience... Learn from it!
HABSFAN2006 is offline   Reply With Quote
Old 06-11-2009, 03:12 PM   #5
Old School
Willie T's Avatar
I don't often give out this secret stuff, but HERE'S your estimator page.
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
Benaiahwannabe (02-05-2014), northernlite (02-05-2014)
Old 06-11-2009, 03:22 PM   #6
Smaller jobs I just buy a 5g bucket of mud
Larger jobs I buy a few
Store isn't that far away for me
Nice calculator
But that means I have to measure
Old 06-11-2009, 03:44 PM   #7
Rewards Points: 150
Wow, great thanks for the link. I know the amount of req'd screws is right on... The amount of tape and primer is also very useful.
Will have to wait a few weeks to see if the estimated weight of mud is correct!
Thanks!
Old 06-11-2009, 05:55 PM   #8
Ron
Are you serious? Are you skim coating the entire wall?
jerryh3 is offline   Reply With Quote
Old 06-11-2009, 07:03 PM   #9
Drywall contractor
You could glaze coat 5 sheets SEVERAL times with a 5 gallon bucket. I'm sure it was a typo....
Old 02-05-2014, 04:47 PM   #10
That is awesome! Thanks!
Benaiahwannabe is offline   Reply With Quote
re: drywall compound over old lath gramps416 Drywall & Plaster 5 01-17-2009 09:51 AM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
Applying Drywall Compound To Sheetrock shapeshifter Painting 9 04-29-2008 04:42 AM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
