How Many Coats - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 05:26 PM   #1
How many coats
Hey,
How many coats of mud do you usually need to finish drywall? 2?3?
TurboDIYer is offline   Reply With Quote
Old 02-19-2012, 05:56 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
3 coats=1 coat as tape bed, 2 coats over tape feathered to finish.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-19-2012, 05:57 PM   #3
Too Short? Cut it Again!
Finish drywall how? Just taping and filling screw or nail holes or are you texturing it or something?
Ideally, for the basics you will have one heavy coat to secure the tape and fill over screw or nail heads. Once the tape is dry and secure, you put another coat over to seal the tape to the wall and hide the seams. Less is more and the less you have to sand the better. Make sure you use a large enough knife too.
Sometimes if the nails or screws got set too deep, pre-mixed compound will "suck in" to the cavities and you have to hit them a second time. If really deep, using "hot" dry mix mud will help.
Old 02-19-2012, 06:29 PM   #4
Rewards Points: 13,472
3 minimim, more if you have never done it before.
Old 02-20-2012, 03:25 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
as many as it takes
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (02-20-2012)
Old 02-22-2012, 11:52 PM   #6
Registered User
Rewards Points: 5,498
As Post 3 (sdsester) said, depends on the finish applied: http://nationalgypsum.com/ng/resourc...revisiting.htm
But as others said- it may take you more to get equal.
Gary
Old 02-27-2012, 09:21 PM   #7
yummy mummy's Avatar
Rewards Points: 1,016
I agree. I had never done it before, and I did 4 coats. Came out really good.
yummy mummy is offline   Reply With Quote
Old 03-02-2012, 05:09 PM   #8
Drywall contractor
Rewards Points: 1,070
How ever many you use, remember "less is more". Don't try to "pile on" a heavy coat. The joints will end up "rounded out" (especially butt joints). Several thin coats are better....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
user1007 (03-02-2012)
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Foam and Elastomeric coats over existing BUR ???? sunguy65 Roofing/Siding 2 02-25-2011 12:48 PM
How many coats of elastomeric coating do we need? bayles Roofing/Siding 5 10-08-2010 01:47 PM
2 coats versus 3 coats joeyboy Painting 9 08-24-2007 11:43 AM
Be honest, do you really do three coats on everything? KUIPORNG Remodeling 18 03-30-2007 03:02 PM
