How To Fix A Wall After Tile Has Been Removed? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 09:02 AM   #1
How to fix a wall after tile has been removed?
I pulled the tile off my kitchen wall and then skim coated it with joint compound to smooth out the dings and dents. Now I am getting cracking in several areas. I have repaired them and now new cracks appear. Any suggestions on how to do this correctly will be appreaciated?
blacksburg is offline   Reply With Quote
Old 03-19-2011, 12:21 PM   #2
Masters in Drywall
MnDrywallRanger's Avatar
Can you post a pic?
Are the cracks a straight line vertical or horizontal on a drywall joint?...or are the cracks a random pattern semi-circular etc?
I have a feeling it may be caused by loose face paper on the sheetrock that got skim coated over and blistered?
I would need a closer inspection with pics to know for sure...
MnDrywallRanger is offline   Reply With Quote
Old 11-08-2011, 02:10 PM   #3
I have a concern in this area too as while I was removing tile, much (ok most) of the face paper is coming off, I still have more tile to remove and may have gotten in the grove to not remove a lot of the face paper. Do I need to replace the drywall or can I skim coat it or put a mesh wire prodcut on the wall before tiling back with new?
slalomskie is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
preperation to paint after wall/ P removed deck hand Painting 4 12-06-2009 01:33 PM
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 02:57 PM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 01:01 AM
