Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-10-2011, 06:31 PM   #1
How to fix crack in butt joint on ceiling
Hi every one, I recently overlayed 3/8" sheetrock over the existing ceiling that had painted swirl finish. I used paper tape on the outside perimeter inside corners and used mesh tape along the seams and butt joints. When applying my final coats of lightweight joint compound that there was a slight hairline crack along the butt joints of the first two sections of sheetrock, so I applied more compound and again saw there is a slight crack along the joint. If I push up against the drywall the crack dissappears because it is hanging down ever so slightly. Should I remove the mud with water and a spounge along the joint and tape with paper and remud? Or should I go in the attic and piece in 2x6 between the joists so I have something to screw into along butt joint and then screw and finally mud over?
kurtinthebox is offline   Reply With Quote
Old 07-10-2011, 07:19 PM   #2
Super Moderator
That's loose and moving---so your idea of blocking will cure the problem---get up into the attic---
Oh, fun---Mike---
oh'mike is online now   Reply With Quote
Old 07-16-2011, 05:33 PM   #3
Drywall contractor
Did you use setting type compound on at least the first coat on the mesh tape?? You should have.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-16-2011, 11:37 PM   #4
Moderator
Back-up for bj; http://www.usg.com/rc/technical-arti...e-en-J1190.pdf
More tips; http://www.usg.com/rc/data-submittal...ata-MH1178.pdf
Gary
Clothes taking longer to dry?
Popcorn ceiling major crack ac5me General Discussion 2 11-26-2010 10:41 AM
how to fix wall joint crack sfcdmu Building & Construction 3 03-24-2009 04:26 PM
Spackle or Joint Compound For Crack ellisje007 General Discussion 11 12-29-2008 07:55 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-17-2007 12:25 AM
