-   -   How to Finish a GROIN Ceiling (http://www.diychatroom.com/f101/how-finish-groin-ceiling-155116/)
newfie49 08-28-2012 01:49 PM
I have an 8 sided 8ft x 8ft Groin ceiling framed and I can hang the drywall ok with 2 layers of 1/4" but need some advice on the best way to finish it with the angles all meeting in the middle and what to tape the curved angles with so they stand out.....its not a big job but just needs to be almost perfect.
newfie49 08-28-2012 02:12 PM
any drywall experts or finishers out there that can help?
joecaption 08-28-2012 04:18 PM
No clue what a groin ceiling even looks like.
Post a picture of the framing.
I do know what a barrel ceiling looks like.
newfie49 08-28-2012 07:39 PM
a groin ceiling is actually a domed ceiling that all joints meet in the middle, this one has square bottom, 8 x 8, with 16" band then begins to arch to center, 8 sections in all, I've done huge domes that are all round but this is both arched and has 4 defined seams starting at each corner gong to center.
I'm trying to figure out what tape to use, arch tape, flex tape? I have a combination of straight lines and curves??
google groin ceiling and you can see samples.....
newfie49 08-28-2012 07:43 PM
groin ceiling sample
http://homebuilding.thefuntimesguide..._vestibule.JPG
newfie49 08-28-2012 07:47 PM
samples
http://heater09.files.wordpress.com/2010/12/roman-a.jpg
Total Tool 08-28-2012 08:55 PM
Not an expert but it looks like you would need to score the backside of the drywall kind of like if you were doing the inside of an arch.
newfie49 08-28-2012 10:04 PM
thanks, Its actually not that hard to hang, I'm looking for some tips on mudding/finishing the ceiling......
joecaption 08-28-2012 10:15 PM
I'd be temped to use plaster instead of drywall.
bjbatlanta 08-29-2012 01:34 PM
You'll basically have to "plaster" it, but it can be done with joint compound. You'll likely have some "stress cracks" in the drywall from bending it. Cut away any paper that comes away from the core of the board and tape those areas. If you have hung radius' before, you probably know it helps to wet the board before trying to bend it into place. Not saturated, just dampened. Sometimes it works just to lay the board on the concrete floor in the basement (if there is one) for acouple of days before you hang it. It will naturally absorb moisture from the concrete. Especially a fresh slab. Looks like the framer did a good job. Be sure to use plenty of glue, it will save headaches later......
Some type of arch bead on the outside radius There are several different types, Strait-Flex is a good product. I'd use mesh on any flat joints. Use setting compound on at least the first coat. I've done barrels, full domes, "eyebrow" dormers, etc. over the years. Can't recall ever doing a groin, but I've seen them and they look good when done properly. Just take your time. Don't try to "pile" the mud on. Several thin coats, sanding in between coats to get your radius smooth.
It's just something you have be patient with. Best of luck!
newfie49 08-29-2012 08:59 PM
thanks, your info helped
bjbatlanta 08-29-2012 09:51 PM
Glad to help. I should have mentioned too that if you have a concrete surface that is not particularly "damp", wet it down with a hose then lay your board on it. It's better to let the rock absorb moisture slowly than to try and get take bucket of water and soak it right before you try to hang it.
Also, I forgot to mention the inside angles. I have used regular paper tape and let it "crease" over itself on the inside of the radius (depending on the curve).
I have actually cut paper tape by hand (on the inside radius side). Or you can use a Strait-Flex type of product too.
newfie49 09-04-2012 04:52 PM
UPDATE, I used hi-flex 1/4" drywall two layers, glued and screwed and it came out perfect, then taped with level line tape and arch strait flex and it really looked good, homeowner I was told would be extra picky but when he inspected it gave me a thumbs up, he plans on building a $40,000 bar in this same area, I maybe should have charged more, anyway another satisfied customer......:thumbsup:
bjbatlanta 09-04-2012 05:34 PM
Glad to hear you were successful! Don't recall having heard of "level line" tape. (Haven't done any radius jobs in a while either.) Can you elaborate or give a source for the product? Always interested researching in new products whether I end up using them or not.....
Total Tool 09-04-2012 11:20 PM
Good to know. You got a pic of the finished product?
