Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-16-2012, 08:07 PM   #1
How to finish a drywall/cement board joint
Hello,
My shower ceiling is drywall (mildew resistant kind) and the walls are all cement board.
How do I finish the joint from wall to ceiling? Do i use a drywall joint mud or do I use thin set? OR do i use both, thinset on cement board and drywall mud on drywall?
I need help...!?
shorteared is offline   Reply With Quote
Old 08-21-2012, 12:49 PM   #2
I noticed nobody answered you so I will give you what I can. I am not an expert at all but have been doin much looking and asking for my project.
The cement board gets mortar and fiberglass tape, that is for sure. Where it meets the ceiling/sheetrock I guess you could go either way. I'm thinking it will matter by how you are wanting it to look. are you trimming the corner?
How are you finishing the wall, are you tileing all the way to the ceiling?
Good luck.
papason is offline   Reply With Quote
Old 08-22-2012, 06:35 PM   #3
Hi there, I decided to post this same message in the construction thread. I got replies right away. I guess I posted in the wrong forum.
The best answer so far is to leave this joint as is because I will be tiling right up to the ceiling then finishing with acrylic caulk...
Thanks for the reply
Old 08-29-2012, 04:08 PM   #4
Drywall contractor
Sorry, (I haven't been on the sight for a while) but that would have been my first question. Tile to the ceiling?? Correct, not taping/finishing needed. Caulk it!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 10:13 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Green board, blue board, backer board??? ddougee Remodeling 5 03-21-2011 10:58 AM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 03:53 PM
