How To Finish Drywall Around This Window - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 09:32 PM   #1
How to finish drywall around this window
What is the best way to finish drywall around this window? L-bead or J-bead?
bkeech is offline   Reply With Quote
Old 02-07-2010, 09:55 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I don't think it would make a huge difference as you will need to caulk where the board lays against the frame anyway. I thing a J is more durable as it encloses the entire end and does not depend on the board to support it as much as with an L bead.
how about an alternative?
just lap the board onto the window frame and then either cut a filler strip the thickness of the board and attach it to the window frame and then overlay a trim moulding from the filler over the board just as you would with a typical installation if you had run the board up to the frame rather than over it.. Or, instead of the plain filler, you could set a trim moulding the thickness of the rock with enough of a flat face to set another trim covering the gap between that moulding and the rock.
Old 02-07-2010, 10:40 PM   #3
Registered User
Rewards Points: 5,236
Why is the window inside the framing rather than outside the concrete or woof foundation wall?
This is not the required 20" minimum wide egress window I hope?
Be safe, Gary
Old 02-08-2010, 09:03 AM   #4
Be safe, Gary
These walls are prefab "superior walls"
Old 02-08-2010, 02:13 PM   #5
Drywall contractor
Rewards Points: 1,070
If you use j-mold you won't have to finish it. Personally I would use some sort of wood.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-16-2010, 06:18 PM   #6
Found out my window is a Boman-Kemp window.
What do you think of this finish method:
http://www.boman-kemp.com/resources/window_finish.pdf
Old 02-16-2010, 07:50 PM   #7
nap
You talking to me?
nap's Avatar
why bother with the moulding? In the drawing you just linked, I would simply use a corner bead and finish the drywall up to the window casing.
Your installation is not like the drawing so it really doesn't make any difference though.
Old 02-17-2010, 06:37 AM   #8
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I agree just put a corner bead on there and sand to a nice finish. From the picture it looks like your window is flush with the inside not the outside so as stated your install is not like the one in the picture.
Big N8 is offline   Reply With Quote
Old 02-17-2010, 02:41 PM   #9
Why not
What is that window looking at? Sheetrock over it completely!
noahweb is offline   Reply With Quote
Old 02-23-2010, 10:32 AM   #10
Rewards Points: 5,336
It seems to be a below grade egress window. It would be hard to get out of if it were covered.
Ron
Old 01-10-2012, 03:56 PM   #11
bkeech - I was wondering if you could describe what you ended up doing and if you could post a photo of the result. I am currently working on my basement and I am in the exact same situation with the superior walls egress window.
Hydra is offline   Reply With Quote
drywall ceiling, how does one finish side steps or racetrack? petenpeg Drywall & Plaster 3 02-06-2010 09:04 PM
Drywall around arched window falling apart Tethered Cat Drywall & Plaster 1 01-10-2010 08:22 AM
Window Install? sod Building & Construction 3 10-26-2008 08:02 AM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
