How To Fill In Space Where Drywall Meets Stone Fireplace? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 02:19 PM   #1
How to fill in space where drywall meets stone fireplace?
Hi All,
I recently remodeled my living room. Previously, the walls were some sort of drywall with plaster over it, now it's just drywall. The problem I have is my stone fireplace sticks out about 2 inches and there's a gap between where the stone and drywall meets. I was thinking of filling the gap in with plaster. Is this the right thing to do? Is it ok to use plaster for this? Does anyone have any suggestions? I've included some pictures. Thanks!
Tom
rizza is offline   Reply With Quote
Old 11-11-2011, 03:05 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good! There's those electron-microscopic photos again.
Why not back away and take a picture that someone can use to see what is going on?
I'm thinking the drywall should have been scribed to the firplace but can't really tell what is there.
XXX
Old 11-11-2011, 06:03 PM   #3
Sorry about that . Hope this is better, thanks for taking the time.
Old 11-11-2011, 06:32 PM   #4
DIY staff
Rewards Points: 7,174
You have some scribing to do-----that needs trim---scribed to the stone--cut carefully and lightly caulked.
Not fun but it's the method I find works best.---Mike---
Old 11-12-2011, 08:15 PM   #5
I agree with the scribe. If you aren't real good at it, you can get close and point the stone.
Jmdesign is offline   Reply With Quote
Old 11-16-2011, 07:47 PM   #6
I am currently refacing my fireplace and had the same issue.
In your case I would use the same trim as you have for chair railing to "frame out" your fireplace.
Everything will match, not to mention adding some depth to your stone facade.
Rotate is offline   Reply With Quote
Old 11-16-2011, 08:44 PM   #7
Thanks All. I will give it a try over the next few weeks. My biggest concern is the depth. Whatever trim I use will need to either be on the thicker side or doubled up with a piece of wood behind it. Thanks again, hopefully I'll be nice and patient as I do this.
Old 11-17-2011, 04:54 AM   #8
DIY staff
I make aggressive copes like that using an angle grinder with 36 grit sandpaper--two disks -back to back'
You tube has some tapes showing the technique--
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
culture stone fireplace takaya Carpentry 0 10-08-2011 11:17 PM
Laminate around a stone fireplace hiswife Flooring 3 04-01-2008 10:24 AM
Drywall to stone transition IraF16 Remodeling 4 03-18-2006 06:28 PM
Drywall to stone transition IraF16 Carpentry 1 03-17-2006 02:02 PM
