| luvdairish |
12-18-2010 11:26 AM |
Thanks for your replies :)
Originally Posted by daveb1
(Post 553117)
Did you apply your wall sheets from the top down or from the floor up? Hanging the top sheet tight to the ceiling and then the sheet near the floor leaves the gap at floor level. Harder to tape and mud down there but easier to hide the gap with baseboard.
Yes I did the top sheet first, but the ceiling was dipping in some areas, so when I butt the top wall sheet, there are some parts of the sheet that wouldn't meet the ceiling piece (hence the gaps). I knew this before hand because I used string to check the ceiling. Since it was only a few small areas, I figured I could fill them somehow and wasn't worth furring and shimming out the entire ceiling.
Originally Posted by 1910NE
I think your best bet will be to cut some scraps to fit, and fill in the holes. as an alternative (and more time/$$) would be to put up crown mold which is big enough to cover.
I don't see a way to cut strips and secure them well enough that it won't have problems later, so I am thinking this will have to be done with mud. Which kind and if there are any tape tricks is what I will need to know from you pros?
Crown Molding is something I wanted to do, but I assume I will have some trouble with gaps there too, no?
