How To Fill This Drywall Gap? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 03:17 PM   #1
Rewards Points: 31
How to fill this drywall gap?
How do I fill this gap? The left side of the picture, that drywall was done by the builder and it's finished. Behind it is a 1/2" OSB and behind the OSB is the 2x4 corner stud. The builder did not finish the wall flush upto the stud so when I finish the corner of the wall (right side of the picture) there is 1/2" gap. How do I fill this in to provide backing for a corner bead? I don't want to rip off the finished wall just to build it up to the corner stud. My first thought was to cut 1/2" OSB and glue it between the gap or maybe just fill it with joint compound, let it dry, then install the corner bead. Any suggestion?
kupalino is offline   Reply With Quote
Old 02-24-2010, 03:18 PM   #2
Rewards Points: 31
Ooops. I attached the wrong picture
Old 02-24-2010, 04:49 PM   #3
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Looks like you are going to need to put "nailers" on both sides. Just take another 2x4 and nail it to the existing wood.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 02-26-2010, 06:45 PM   #4
You can also try using a stick of oversized corner bead. Check out:
http://www.hamiltonnw.com/AP_TrimTex...ornerBeads.asp
drywallIdaho is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Need to fill nail holes in drywall, what to use? twilightcall Building & Construction 3 05-12-2008 09:20 PM
Gaps in drywall. What to use to fill them in. yummy mummy Building & Construction 13 01-02-2008 01:19 PM
