How To Fill Around This Box - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 03:01 PM   #1
How to fill around this box
The plaster in the picture is about 1" deep. It was made the old fashioned way with layers of different plaster. Is there a single product today that I could use to fill a 1" deep x 1" wide gap like this or do I need to square the hole better and tape in pieces of drywall before I patch it?
Before you say I should have used an old work box, there's a ceiling inside the wall directly above where I want the bracket, so the wings wouldn't work (yes, I could have put the box slightly lower, but I didn't and I prefer the more secure new work brackets), and there's a wall directly to the left so a mud ring wouldn't work. I plan on installing a "screw block" behind the mesh with lath screws so I could screw in the bracket.
Dorado is offline   Reply With Quote
Old 04-13-2013, 04:13 PM   #2
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
What's going in the pipe?
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
The Following User Says Thank You to HARRY304E For This Useful Post:
joecaption (04-13-2013)
Old 04-13-2013, 04:28 PM   #3
Two coaxial cables, but I may split them when they exit the tube so I'll have four coming out of a wall mounted box. I'll put raceway there eventually.
Old 04-13-2013, 06:54 PM   #4
Too Short? Cut it Again!
Could try canned foam. Then saw it off flush and skim coat to match the wall.
Build it back up with patching plaster? Drywall mud doesn't always work so well in big amounts with plaster.
They make mesh patching material that is rigid. Cut it, apply mud to blend it in. Paint store will have large pieces but a box store will probably only have little ones, if at all.
Old 04-13-2013, 10:05 PM   #5
I just remembered that I have fire block sealant but I'm not sure if anything sticks to it and it doesn't say how thick you can make it. I think I'll use it and put drywall tape over it. The rigid patch sounds thick.
Old 04-13-2013, 10:55 PM   #6
Two ways I would do it depending on how much time you want to spend on it, and skill level
Mesh first then a fiberglass reinforced mortar or bonding cement then plaster (not joint compound)
Or a quicker way would be mesh and bondo sand to desired smoothness
jsbuilders is offline   Reply With Quote
Old 04-17-2013, 04:14 PM   #7
I assembled the Wiremold "starter box" temporarily to see how everything fits. The low voltage bracket will stay in there when I fill around and behind it. It flexes slightly but it's strong enough for driving screws. No decision on the fill yet.
Old 04-30-2013, 10:14 AM   #8
Rewards Points: 578
You could get a jumbo size faceplate at Home Depot... not the best option but it might work...
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 04-30-2013, 11:12 AM   #9
I filled it with a fire caulk and joint compound and used a single gang box. The first three coats of joint compound cracked a little (parts were 1/2" thick), but the last one worked. I'm adding another coat because I want the box to lay slightly more flush against the wall with no gaps. There are two pipes in the wall covered with asbestos and a breeze comes from the hole on windy days. I may look into how to test air for asbestos.
How to fill around this box-hallway-box-opened-closed.jpg   How to fill around this box-pipe-wall.jpg
Old 04-30-2013, 12:59 PM   #10
Rewards Points: 744
asbestos testing isn't really a DIY task. Have a testing company come in and do an air sampling. They'll then analyze it under microscope and let you know how much is in the air.
Seattle2k is offline   Reply With Quote
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 07:03 AM
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 04:30 PM
Leaking Fill valve tallman Plumbing 1 07-14-2011 01:01 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
