How Far Below The Ceiling Does This Joint Get Finished? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-24-2014, 09:57 PM   #16
Rewards Points: 1,092
just fyi: when i said "mud", i meant regular sheetrock mud. everything i know about spackle, i just read above.
Old 01-25-2014, 08:46 AM   #17
Handyman
Rewards Points: 512
You can purchase small packages of Sheetrock 20 or 45 which dry fairly fast. Apply the mud over the screw holes in one direction and wipe off with a perpendicular stroke
canadaclub is offline   Reply With Quote
Old 01-25-2014, 10:28 AM   #18
Rewards Points: 6,034
Haven't seen the 20 or 45 in anything but the big bigs here but you can get the 5 minute in a small pack. Mix with cold water and you can buy a little more time.
Old 01-25-2014, 10:34 AM   #19
Having said that why are you doing the nails. This will be part of the finishers job and included in the price. If you go around and use something like spackle and he has to go around and dig it all out he is going to charge you more. Same with the mud mix you get something he has problems sanding or can't sand and it could be a costly mistake In fact I know some finishers that would not do the job if you did that..
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 06:16 PM
How to fix crack in butt joint on ceiling kurtinthebox Drywall & Plaster 3 07-16-2011 10:37 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Drywall to Textured Ceiling Joint finishing tmbrink Drywall & Plaster 3 02-04-2010 10:03 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
