How Far Below The Ceiling Does This Joint Get Finished? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-22-2014, 02:55 PM   #1
Rewards Points: 422
How far below the ceiling does this joint get finished?
How far below the ceiling does this joint get finished? 2", 3", 4" ? I'm asking because we just drywalled my daughter's basement ceiling, and there's only about 1.5" between the top of door trim and bottom of soffit ceiling. If I pop off the top door trim, there would be about 4" I think. I assume I MUST take the casing off? Thanks.
Jim McC is offline   Reply With Quote
Old 01-23-2014, 10:45 AM   #2
Professional
TotalHomeworx's Avatar
Yes, you want to remove all door and window casings. The purpose of the trim is to cover the gap where the drywall meets the door/window jam. Baseboard is to cover the gap between the bottom of the drywall and the floor.
TotalHomeworx is offline   Reply With Quote
Old 01-23-2014, 01:32 PM   #3
Rewards Points: 422
So how much room will the finisher need to do the seam where the ceiling meets the top of wall?
Old 01-23-2014, 01:39 PM   #4
Professional
As much as you can give him. If you only have 4 inches then that will have to do. 2" and go around casing is not fun.
Old 01-24-2014, 01:32 PM   #5
Rewards Points: 422
Thanks. Is it OK to use spackle on the screw holes of new drywall? My daughter's are trying to find a finisher, but in the meantime I thought about doing the screw holes at least.
Old 01-24-2014, 01:58 PM   #6
Rewards Points: 1,092
screws are generally covered at least twice. use at least a 4" knife. wipe clean and sanding will be minimal, if at all. if you hit any with the knife, screw 'em in more.
Old 01-24-2014, 03:50 PM   #7
Rewards Points: 422
Thanks. So spackle will be OK then?
Old 01-24-2014, 05:14 PM   #8
regular sheetrock mud. same stuff that goes around the tape.
Old 01-24-2014, 07:43 PM   #9
Rewards Points: 422
I was asking if spackle(lightweight vinyl) was OK because it dries quickly, and I can do both coats tomorrow. They live 45 minutes away.
Old 01-24-2014, 08:30 PM   #10
oh. never used spackle, but if you mud the nail holes in the a.m, they should be dry in a few hours. that assumes your humidity is not extreme and it is fairly warm in the room; comfortable. screw holes are generally very shallow.
Old 01-24-2014, 08:30 PM   #11
Rewards Points: 5,974
NO no spackle, do not use spackle, no spackle will not work.
Old 01-24-2014, 08:38 PM   #12
Rewards Points: 422
Thanks. Neither regular nor lightweight spackle will work for the screw heads?
Old 01-24-2014, 09:19 PM   #13
That is correct.
Old 01-24-2014, 09:37 PM   #14
Rewards Points: 422
Is the because the holes are too wide?
Old 01-24-2014, 10:31 PM   #15
Jmayspaint's Avatar
Rewards Points: 534
Basically. Spackle is really only useful on small holes and gouges. The lightweight stuff is brittle when it dries, and tends to crack/ fall out when over applied.
Technically, a heavier vinyl spackle might be OK for just the nails BUT if you are going to have a finisher come in later they likely won't appreciate it being used. Having mud of different hardness/ texture on one wall can be a real pain.
Vinyl spackle is usually difficult to sand also.
Jmayspaint is online now   Reply With Quote
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 07:16 PM
How to fix crack in butt joint on ceiling kurtinthebox Drywall & Plaster 3 07-16-2011 11:37 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Drywall to Textured Ceiling Joint finishing tmbrink Drywall & Plaster 3 02-04-2010 11:03 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
