Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-07-2009, 01:49 PM   #1
How to emove can light without damaging drywall
Late 80s vintage home. Can light has stopped working. I cannot remove the housing from the ceiling to get to the wiring to see what problem is. Do not want to damage ceiling. Appears to be held by tension in the drywall. Suggestions?
nashcat is offline   Reply With Quote
Old 09-07-2009, 02:07 PM   #2
Tool Geek
PaliBob's Avatar
Nash, Welome to the forum.
Cans come in all different diameters and as new or remodel models.
Can you post a pic?
With the bulb removed, can you see any 1/4" hex head screws in the sides of the can?
& Stay Safe
.....Bob Lavery
Old 09-07-2009, 03:26 PM   #3
300zx's Avatar
Post
Follow Bob and Househelpers instructionsso
300zx is offline   Reply With Quote
Old 09-07-2009, 03:28 PM   #4
Licensed Pro
All can lights are designed to be removed to access the wiring. There are either screws holding it in place as palibob said, it is held in place by spring tension, or if it is a remodel can, by spring clips holding it to the ceiling surface.
Old 09-08-2009, 06:52 PM   #5
1880's?
I KNOW that late 1980's isn't vintage yet.
220/221 is offline   Reply With Quote
Old 09-08-2009, 06:57 PM   #6
nap
You talking to me?
nap's Avatar
the housing is generally not intended to be removed but the wiring is accessible through the trim hole.
It sounds like you may have the trim out already. Do you?
Work on a few of those and you will see that electricians really do work for their money, especially if you have large hands.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
Best way to hide overcut drywall with light socket Red Squirrel Drywall & Plaster 7 08-17-2009 12:24 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
