How Do I Fix THIS - Pics Included. - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 04:36 PM   #16
Rewards Points: 6,034
Yep take it down, buy a new tape measure and try again.
Old 08-07-2013, 08:37 AM   #17
I opened Pandora's box, guys. As you will see I took on the BIG hole, the one from the picture in the original post, and it is not straight. I had a stencil done but cutting in straight lines is a lot more difficult than it seems.
I have a lot of respect for you DIY guys. If I ever get around to completing this mission - which is a MASSIVE 'if' - I'm going to retire from the DIY game and revert to paying people like yourselves to do my dirty work.
Shane1988 is offline   Reply With Quote
Old 08-07-2013, 12:57 PM   #18
what are you trying to cut with? this is where a level and a pencil come in handy and you can follow the line. I'd clean up those holes and then cut the appropriate pieces. Or just rip out the whole sheets and start over in those spots, haha. Also make sure you have the drywall facing the right direction.
bova80 is offline   Reply With Quote
Old 08-07-2013, 03:01 PM   #19
Measure the hole, cut your repair larger, hold the repair piece over the hole, trace the repair piece outline on the wall. Using a jab saw(a pointed saw used to cut drywall, cost about $10) or with a sharp utility knife cut along the tracing till you are clear thru. Now even if not straight the hole will be the same as the patch.
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 04:34 PM
Help Identifying a problem with my brickwork (pics included) feroxide Building & Construction 9 04-03-2011 05:04 PM
Color suggestions for exterior of house (pics included) gordholio Painting 1 07-05-2009 08:04 AM
Repairing interior wall cavity with mold, what would you do? (Pics included) pendlebg General DIY Discussions 4 06-16-2009 03:40 PM
